Dec 20, 2008, 05:24 PM
Personal Sales Rating: ( 0)
Drives: 2004 Lancer Ralliart DWP
Premium rotor suggestions??
Anybody heard of these guys??? Brakeperformance.com
PREMIUM DIMPLED & SLOTTED (BLACK)
FRONT SET - TWO (2) ROTORS #RB-46061
FREE SHIPPING • FREE BRAKE PADS • LIFETIME WARRANTY!
$180.75 set of two front rotors w/ceramic pads for extra $10.00
warp free for life
DIMPLE-DRILLED & SLOTTEDPartially Drilled Holes Dissipate Heat without Sacrificing Strength
(Lifetime Warranty against Warping) See Below For More Features
Offline
Dec 20, 2008, 05:56 PM
I was also wondering if Dimpled + slotted were suitable for DD. I have decided against crossed drilled after reading several post, is dimpling adding anything beneficial over just slotted rotors. (vented only is only 2 yr warrany vs lifetime for dimple+slotted). Thinking of these with EBC Red pads???
Offline
Dec 21, 2008, 01:14 AM
Personal Sales Rating: ( 5)
Drives: 05 Pearl White Ralliart AT
I haven't heard of that brake company before but I just bought some dimpled/slotted rotors for my RA and once you find out how it goes let me know cause I'm not installing them til spring time...
As for the pads... if you're only using this car as a DD then I woudln't suggest the Reds because unless you're going to track the car you won't get the pads hot enough for their full potential use... this is what I've heard so if I'm wrong don't flame me... but if you want to go with the EBC brand you should be able to use the Greens no problem
__________________
Power: [x] RRM SRI [x] RRM UDP [x] RRM RA Timing Controlbox [x] RRM P/P Intake Manifold [x] RRM P/P Head [x] RRM Header/DP/HF Cat [x] Magnaflow Catback
Aesthetics: [x] Vortex Generator / Shorty Antenna [x] Angel Eye Projectors [x] 6000K Headlight HIDs [x] RRM Black Tails
Handling: [x] Megan Street Coilovers
Future Mods:
[ ] RRM Anti-Sway Bar
[ ] RRM Lower Tiebar
[ ] RRM Piggyback
[ ] RRM Stage 2 Cam
[ ] R1 Premium Rotors
Offline
Dec 29, 2008, 07:12 PM
I thought the reds were not suggested for track use, at least on EBC website. I do alot of stop & go driving (traffic) should't that heat up the pads???
Offline
Dec 29, 2008, 07:15 PM
Personal Sales Rating: ( 1)
Drives: 2003 evo
rotorpros on ebay do a search on them theres alot of good feedback and resonably priced
__________________
injen upper and lower i/c pipes, invidia dp, hallman mbc@28psi, megan o2 housing, gt spec manifold, buschur 20g-9-5, buschur 780 inj, hks carbon ti exhaust, ur cat delete, 255 walbro, ams licp, act hdss clutch, bc 272 cams w/hks cam gears, turboxs fmic, aps bov
Tuned by Mellon
Offline
Dec 29, 2008, 07:35 PM
yes stop and go traffic would heat them up but i dont think hot enough that would be enough to get the full potential out of them
__________________
Future Mods:
[ ] RRM Piggyback
[ ] RRM Stage 2 Cam
Offline
Jan 9, 2009, 02:15 AM
Drives: 2004 Black Ralliart MT
in terms of brand, i would go with a brand with a reputation within this community for our cars, like R1 Concepts. They had a forum discount goin on a while back, not sure if it's still goin. They're premium line is great quality and they have great customer service.
as for slotted & dimpled, i say go for both. you already know cross-drilled is a bad idea. from my understanding, dimples essentially add volume displacement of hot gas from the pads to the displacement you get from slots. I got both slotted and dimpled, and I'm very impressed so far. I've done two mountain runs so far to test them out. Yesterday I descended a twisty mountain using the brakes hard, intending to see if I could get them to heat up too much. Didn't feel like I even got close. They stayed well within their comfortable temp range with no hints of fade. That's with R1 concepts premium & Hawk HPS.
Keep in mind though, slots and dimpled will only come into play when the pads are hot enough to break down their resins and release hot gases, which happens when you're using mostly abrasive friction forces, which won't really be the case in every day driving. Point being, you'll only notice a difference when you're consistently using the brakes fairly hard. Someone correct me if I've explained something poorly.
As for pads, I personally recommend EBC redstuff or Hawk HPS. I've liked both and both are on the low dust end of the spectrum compared to similarly-performing pads. If you won't be doing much aggressive driving or any auto-x, I'd say EBC greenstuff would be just fine for you.
__________________
Romans 1:16-17:
"For I am not ashamed of the gospel of Christ, for it is the power of God to salvation for everyone who believes, for the Jew first and also for the Greek. For in it the righteousness of God is revealed from faith to faith; as it is written, 'The just shall live by faith.'"
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
