Oct 4, 2007, 01:46 PM
Personal Sales Rating: ( 1)
Drives: .
Spring / Coilover Buyer's Guide (CS7A chassis)
Removed.
Done trying to be helpful here.
__________________
Offline
May 9, 2008, 05:17 PM
Drives: 2006 Lancer RA
KW is now producing a set.... I'll give you model number when I'll get it
Offline
Feb 12, 2009, 07:22 PM
Personal Sales Rating: ( 0)
2004 Mitsubishi Lancer
Drives: 04 Lancer Ralliart
I checked the Megan site and it looks all great untill i see that its ment for Lancer es/oz, will it still fit a ralliart, im thinking yes, it should be the same set up, just the RA has better components? If so this sounds like a whole better deal than RRM's Tein, plus cheaper, + more features!
Offline
Feb 12, 2009, 08:22 PM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Quote:
Yes, the Ralliart's suspension is identical to the OZ, just slightly different valving on the OEM shocks. As far as coilovers and aftermarket springs go, all the 02-06 Lancers, except the evo, can use the same parts.
Offline
Feb 21, 2009, 10:15 PM
KW finally can't do the rear shocks so it's a no go but BC racing B-03 is our apllication.
Comes with 8/6K spring rate
They have 2 versions : BR regular for street use and RAM (inverted) more for track.
Offline
Apr 8, 2009, 11:17 AM
Progress specs are (from their website)
-Front drop: 1.0" --- Rear drop: 0.5"
-Front rate: 180 lbs/in --- Rear rate: 175 lbs/in
Offline
Apr 10, 2009, 08:23 AM
So now im between Megan or Tein SS?
Offline
Apr 17, 2009, 05:29 PM
Here's our BC racing...
Offline
Jun 2, 2009, 03:51 AM
Personal Sales Rating: ( 5)
Drives: 05 Pearl White Ralliart AT
I was looking into getting some coilovers and besides RRM i don't really know where else to get coilovers for my 05 RA... is it completely impossible for evo coilovers to work on our cars? i just find that they're more common in the for sale sections then ones for RAs...
Offline
Jun 2, 2009, 10:13 AM
Drives: .
__________________
Offline
Jun 2, 2009, 12:49 PM
Quote:
Originally Posted by Eclipse2Lancer
No Evo. Completely different chassis.
Actually, identical chassis, just different suspension and weight distribution  Evo fronts will bolt up, however, the spring rates and valving will be wrong for the lighter Ralliart. The rears won't bolt up at the bottom at all, and even if they did, the valving would be WAY off.
Offline
Jun 3, 2009, 08:26 AM
Drives: .
__________________
Offline
Jul 17, 2009, 11:38 PM
Drives: 04 lancer ralliart
www.stdsuspension.com 5 different model from street to track
Offline
Jul 30, 2009, 03:46 AM
Drives: 2004 Lancer Ralliart
i hav a question, i was thinkin of goin wit bags for my 04 RA, wat do ya'll think? good or bad? i kno its possible, ive seen it done too, thing is i will be goin turbo soon or later, but she be mostly a show car, but i want her to reach 350-400hp, wat do u think?
Offline
Jul 30, 2009, 09:11 AM
Drives: .
__________________
Offline
Tags
chassis, coilover, conversion, guide, inch, instructions, jic, kg, lbs, mm, rate, shocks, spring, springs, suspension, table  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
