Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart How-to's/Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Closed Thread
Old Mar 18, 2007, 07:24 PM   #1
Personal Sales Rating: (1)
redlne8's Avatar
Drives: 2005 Mitsubishi Lancer Ralliart
HOW TO: Install A/F Guage
This is a general "How To" on installing an A/F guage. -
Tools needed:
*18 Guage wire
*Wire Nuts/Electrical Tape
*Wire Stripper
*Drill
*X-ACTO Knife
*Patience
1. Start out by routing the RED wire from your A/F guage to a +12V ignigion supply
(a very easy tap would be to your ACC line on your car's CD head unit).
2. Route the black wire to a good ground connection and secure tightly.
3. The third wire will be the one we use to tap into the O2 sensor. You will need to drill a small hole in your firewall to route the wire down through your engine bay and back to the O2 sensor (I drilled mine right below the throttle cable). Be careful the wire does not get too close your your exhaust piping! For this step I did a "cheater" way if you are leary about actually splicing or cutting anything. You want to pull the sleve cover back and then shave the insulation off the BLUE wire of your O2 sensor. Once you have a good inch of wire exposed wrap the last wire (that you routed) from the A/F guage around this exposed portion and tape up tightly to prevent moisture. Slide black sleeve that cover O2 Sensor wires back over and your done.
-Matt
__________________
2005 Lancer Ra//iart
- Eibach Pro Springs - Apex-i catback exhaust - AEM Intake - RRM Header - RRM Down Pipe - RRM CAT Delete - RRM Pully - RRM LSD - Pirelli P-ZERO NERO Rubbers - SpeedSource Brass Underhood Shifter Bushings - Kaixen 6000K HIDs - - Authority Short Shifter - SpeedSource Aluminum Shifter Base Bushings - - GlowShift A/F,Oil Press & Voltage Guages
Offline
Old Mar 18, 2007, 09:31 PM   #2
EvoM Super Moderator
Personal Sales Rating: (10)
2009 Toyota Tacoma
My Garage
otter's Avatar
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Send a message via AIM to otter
Couple notes on this. It's for a narrowband A/F meter, not wideband, and you dont' need to drill a hole in your firewall. There are already many holes there stock for us to use.
Discuss here.
__________________
READ EVERYTHING IN THIS LINK BEFORE PM'ING ME ABOUT WHY YOU CAN'T POST IN THE CLASSIFIEDS!!!
Problem with a post or thread? Use the report post button, it's faster than PM'ing a single Mod.
Read and obey the rules to help keep this forum a great place!
My Ralliart
Michigan Evo/Lancer club
Online
Closed Thread
Tags
aem, af, evo, guage, guages, install, installation, installing, meter, o2, ratio, routing, sensor, wideband, wire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
