Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart How-to's/Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Closed Thread
Old Dec 25, 2006, 09:27 AM   #1
Personal Sales Rating: (2)
Diavlo's Avatar
Drives: Evo IX FQ-340
Engine Swap - Convert to a RA
Having recently completed an engine swap to convert my UK 1.6 Lancer to the 2.4 MIVEC motor, I thought I'd compile this rough guide just encase anyone blows their motor and wants to go this route.
What I must stress however, is that it is NOT worth doing this swap to a perfectly good ES or OZ Rally, you might as well just trade in for a RA. I did not have that choice as the 2.4 is not available in Europe or anywhere except the USA, Canada, Australia and a few other far-off locations from the UK!
1.6:
2.4:
So heres my thoughts and a rough guide.
Summary
The previous engine was a 4G18, 96Bhp 1.6L powerplant, using a return-type fuel system.
The RA engine is 4G69, 162Bhp 2.4L powerplant with MIVEC, using a returnless-type fuel system.
How difficult was it?
Contrary to popular fanboy belief - it is very easy to swap to the 4G69, as everything bolts up, fits, and no custom work is required. It does however take a lot of money and time.
It is VITAL you make sure you have all the correct parts. It is not as simple as changing the engine. You need the new axles, the new transaxle, new wiring harness, ECM, tubes, fuel pump, and much more.
What did we anticipate would work but didnt?
We anticipated that we could re-used the transmission - we couldnt - it was subtly different. Short story - you need the RA transmission, changing just the clutch housing wont work.
We thought then after getting the new transaxle that we could re-use the old axles - WRONG! The RA axles are thicker, and old thinner axles wont turn in the RA differential.
What did work suprisingly?
The wiring harness for the engine connected up really well for the most part. On my car there was one particular plug C-124, that needed a few changes, but this may not be the case on a USDM lancer.
The engine started up without any major problems.
What parts did we need?
4G69 engine (doesnt matter if it is from AT or MT, but if it is from an Auto like mine was youll need a flywheel and clutch. Also make sure it has everything left on it, like the starter etc)
4G69 transaxle
4G69 drive axles
4G69 ancillaries if not on engine (ps pump, ac compressor, alternator)
ECM
Engine Wiring Harness
Exhaust
Fuel Pump
How do you do it?
In very simple steps:
1). Drain your fluids
2). Disconnect all wiring and hoses
3). Remove as much as you can from the engine to aid hoisting, such as the exhaust manifold.
4). Remove the engine. For this there are two options, either unbolt the transmission/clutch housing from the block and then take out just the engine, or you can drop the whole lot down if you can raise the car on a lift.
5). Remove the engine wiring harness and ECM
6). Prepare the car for the new engine, such as installing the new engine wiring harness and ECM. We also changed the clutch master cylinder but this is not necessary.
7). We put the new engine in with the transmission attached. This is difficult from the top so its better to drop the car onto it. If you remove all the brackets from the engine and get the header off of it, it will go in from the top.
8). Put in the new axles, then fill your fluids.
10). Check everything over, but it should be ready to roll now.
__________________
1.6 > 2.4 Engine Swapped Lancer - Stolen & Lost
New car: Evo IX FQ-340
My CarDomain
Offline
Old Dec 25, 2006, 03:44 PM   #2
EvoM Super Moderator
Personal Sales Rating: (11)
2004 Mitsubishi Lancer
My Garage
otter's Avatar
Drives: often.
Send a message via AIM to otter
Discuss here.
Diavlo, if you ever need to add more, let me know and I can unlock it for you.
__________________
READ EVERYTHING IN THIS LINK BEFORE PM'ING ME ABOUT WHY YOU CAN'T POST IN THE CLASSIFIEDS!!!
Problem with a post or thread? Use the report post button, it's faster than PM'ing a single Mod.
Read and obey the rules to help keep this forum a great place!
My Ralliart
Michigan Evo/Lancer club
Offline
Closed Thread
Tags
24, 4g69, cardone6jpg, ecm, engine, evo, guide, ix, lancer, motor, ra, ralliart, swap, tranny, transmission, wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
