MOMO Evo 8 Steering wheel install
Quoted by "Genki"
Before you begin:
- disconnect negative cable from the battery.
- Lock steering wheel so it doesn't turn.
To Remove Stock Steering Wheel:
- Remove cap at the bottom of the stock wheel to reveal SRS/horn/cruise control wires.
- Disconnect all the wires.
- Use an Allen key to loosen the screw that's holding the steering wheel to the steering column . (screw is on the left side and will take a bit of strength to get it to turn. turn it all the way till it comes off)
- Once the screw is off, the steering wheel should come off easily by pulling it.
To Install EVO VII/VIII Steering Wheel:
- Connect the wires for the SRS and horn
- Put the steering wheel on straight and push down until it clicks
- Tighten the screw with the Allen key.
