Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart How-to's/Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Closed Thread
Old Mar 17, 2005, 01:51 PM   #1
Personal Sales Rating: (4)
pocoRA's Avatar
Drives: 2004 Black RalliArt
SS Clutch Line/Slave Cylinder bypass
Tools needed:
-12mm Wrench
-10mm Line Wrench
EDIT: Use a line wrench! The fittings have loc-tite on them, and a normal 10mm wrench will round off the fittings --Otter
(You can use a non-line wrench, but be careful.)
This is a simple upgrade install that involves more pictures than words.
The only difficult/time consuming part of this install would be bleeding
the clutch.
Removal:
1. Remove your intake system. (not necessary if you already have a CAI)
2. Loosen each 10mm nut on the end of each side of the slave orifice.
3. Loosen the (2) 12mm bolts that secure the clutch slave orifice to the
transmission and remove as a whole piece.
4. Install the new steel braided line.
5. Bleed the clutch system and check for leaks.
-Bleeding the clutch will require 2 people
-Make sure brake fluid reservoir is full past the max line.
-Have someone in the car pump the clutch a few times, then open the bleeder valve, and have them push the clutch to the floor and hold it there, while the clutch is to the floor, shut the bleeder valve.
-Repeat that until there is a steady stream of fluid coming out of the bleeder valve, then top off the fluid, and you're done.
__________________
RRM Downpipe with High-Flow Cat (Off car, for sale.)
Progress Springs (off car, for sale.)
Stainless Steel Clutch Line
Progress Rear Sway Bar + Perches
B&M Short Shifter
SpeedSource Brass Bushings
Offline
Old Mar 17, 2005, 09:19 PM   #2
EvoM Super Moderator
Personal Sales Rating: (10)
2009 Toyota Tacoma
My Garage
otter's Avatar
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Send a message via AIM to otter
Thread closed. Futher discussion goes here.
__________________
READ EVERYTHING IN THIS LINK BEFORE PM'ING ME ABOUT WHY YOU CAN'T POST IN THE CLASSIFIEDS!!!
Problem with a post or thread? Use the report post button, it's faster than PM'ing a single Mod.
Read and obey the rules to help keep this forum a great place!
My Ralliart
Michigan Evo/Lancer club
Online
Closed Thread
Tags
called, clutch, cylinder, evo, evolution, evolutionnet, install, lancer, line, master, michigan, orifice, removal, slave, ss
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
