Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart General
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 28, 2009, 05:35 AM   #1
Personal Sales Rating: (0)
Drives: 06 RA
Help Needed
Hi everyone
I was fixing up my gauge which I accidentally knocked over and pulled the wires out (which were tapping power from the Headunit). I think the force was hard enough that even the ground wire came off - and therefore might have short circuited the electrics. My car is an AUDM 06 Lancer ES (which has the Ralliart Engine). Currently, the following are not working:
1) Dash clock - no lights; nothing.
2) Interior light - does not turn on at all.
3) Headunit doesnt work at all - only the Pioneer one doesnt work, i tried the OEM Mitsu one and that seems to start up.
4) Headlights - will not work when car is off (key in ignition at LOCK position. Warning sound also not evident.
5) Central locking not working - both manually and with remote.
6) Trip meter will reset itself every time I turn off the car.
7) Everything at the dash doesnt work when the key is in ACC position.
Tested and working when the engine is started and key position is in ON:
1) Air-con - all fans, heater and cooler working.
2) Headlights - low beams and high beams work fine when car is on.
3) Signals
4) Brake lights
5) Cluster lights
6) Cruise control light
7) Cigarette lighter
8) Power windows
9) It drives.
What do you guys think is wrong? I havent done any diagnostics yet.
Thanks
Offline
Old Oct 28, 2009, 07:53 AM   #2
EvoM Moderator
Personal Sales Rating: (8)
2004 Mitsubishi Lancer
GearDownSon's Avatar
Drives: a boosted Ralliart ;)
I gotta ask the obvious. Did you check the fuses?
__________________
RRM ralliart turbo self installed.
Dont hesitate to PM me with any questions an i will do my best to help ;)
Please read through the rules if you have any questions or doubts about your post.
http://forums.evolutionm.net/evom-an...uncements.html
Quote:
Originally Posted by HobieKopek
You'll be fine. You just may feel sore for a while. I bled for 3 days (not much, but enough to taste like I had a mouth full of pennis), but I also had Percoset (sp?) which meant I had a pretty good time.
Offline
Old Oct 28, 2009, 06:38 PM   #3
Drives: 06 RA
checked a couple already. those that i checked are fine. except i cant seem to get the cabin lamp and radio fuse in the engine fuse box out. it has this yellow holder keeping them in.
Offline
Old Oct 28, 2009, 07:04 PM   #4
EvoM Moderator
Those very well may be the ones that are blown.
__________________
Offline
Old Oct 28, 2009, 09:49 PM   #5
gary_06ralliart's Avatar
Drives: 2006 ralliart
check those that you cant get out, you have to pop the yellow peice off, then check the ones under the hood, everything should be fused, so you probably just blew a bunch
__________________
WANTED TO BUY, HEADER AND DOWNPIPE! PM ME IF YOU HAVE ONE!
Offline
Old Oct 29, 2009, 01:35 AM   #6
Drives: 06 RA
thanks guys. uve been a great help. it was the fuses that had the yellow piece on them. all is good now
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
