Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart General
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 17, 2009, 12:32 AM   #1
Personal Sales Rating: (1)
soulesswarrior's Avatar
Drives: Lancer ralliart
running hot
ok so i noticed this once befor on a longer trip, my car started to raise the temp gauge. but never to the red always about 3/4 the way then it bounces from there to normal. after the car sat over night it hasnt happened again until tonight, that was about a month ago. tonight i barely drove maybe 10 miles temp fine. car was parked for bout an hour than went 1/2 mile to the freeway and al the sudden the gauge shot up 3/4 and has been hopping around since. i noticed the top raidator hose is really hot while the lower is not hot at all, this im not sure if its normal or not. any suggestions? i dont really have the money to try and go through all the solutions through elimination the car has 103k, my friend said it could need to be flushed, could be bad hose but i pulled the hose off it seemed fine. and yes theres plenty of fluids. any help would be great
Offline
Old Oct 17, 2009, 07:32 AM   #2
Personal Sales Rating: (0)
zebra4's Avatar
Drives: 2005 Lancer RA MT
thermostat not opening?
Offline
Old Oct 17, 2009, 08:13 AM   #3
EvoM Super Moderator
Personal Sales Rating: (10)
2009 Toyota Tacoma
My Garage
otter's Avatar
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Send a message via AIM to otter
Yeah, I would guess your thermostat is sticking, replace it. It's a cheap part and easy to get to.
__________________
READ EVERYTHING IN THIS LINK BEFORE PM'ING ME ABOUT WHY YOU CAN'T POST IN THE CLASSIFIEDS!!!
Problem with a post or thread? Use the report post button, it's faster than PM'ing a single Mod.
Read and obey the rules to help keep this forum a great place!
My Ralliart
Michigan Evo/Lancer club
Online
Old Oct 17, 2009, 12:19 PM   #4
EvoM Moderator
Personal Sales Rating: (8)
2004 Mitsubishi Lancer
GearDownSon's Avatar
Drives: a boosted Ralliart ;)
Quote:
This
Or it could be the fan controller.
Mine would raise while idle then drop back down once i got going.
I was thinking thermostat as well but it wasn't. Just a suggestion.
__________________
RRM ralliart turbo self installed.
Dont hesitate to PM me with any questions an i will do my best to help ;)
Please read through the rules if you have any questions or doubts about your post.
http://forums.evolutionm.net/evom-an...uncements.html
Quote:
Originally Posted by HobieKopek
You'll be fine. You just may feel sore for a while. I bled for 3 days (not much, but enough to taste like I had a mouth full of pennis), but I also had Percoset (sp?) which meant I had a pretty good time.
Offline
Old Oct 17, 2009, 01:03 PM   #5
i do know my fan controll unit is messed up but the fans come on still. mine does not raise at idle it drops. and definatly raises when i go up hill
Offline
Old Oct 17, 2009, 02:26 PM   #6
2009 Toyota Tacoma
My Garage
otter's Avatar
No way it's the fans. The hose is the clue to this one. Hot upper hose and cold lower. The coolant flows out of the engine block into the lower hose, which is where the therm. is located. Cold lower hose means that the coolant isn't being allowed to leave the block and the thermostat would be the only cause of that.
__________________
My Ralliart
Online
Old Oct 17, 2009, 03:29 PM   #7
well my gf is going to get my new thermostat now. but i took the old one and boiled it to test it and it seems to be opening and closing. but it goin bad could explain why the gauge hops around?
Offline
Old Oct 17, 2009, 06:27 PM   #8
after a test drive going uphill it still raised with a new thermostat... any other ideas?
Offline
Old Oct 17, 2009, 07:06 PM   #9
2006 Mitsubishi Lancer
Thomar's Avatar
Drives: 2006 Mitsubishi Lancer Ralliart
perhaps there's something blocking the coolant through the radiator or a hose somewhere.
try this: remove the thermostat all-together. Go for a drive. Still heats up?
Offline
Old Oct 17, 2009, 07:37 PM   #10
EvoM Moderator
Low coolant?
__________________
Offline
Old Oct 18, 2009, 10:00 AM   #11
Well I burped the system again and it didn't heat up for a good drive. It did rais slightly on the hill in my diveway at the end of the drive so I reburped it so I'll keep an eye on it today. It doesn't seem like theirs any blockage in the hoses. And there's plenty of coolant
Offline
Old Oct 19, 2009, 08:39 PM   #12
SSP-Ralliart's Avatar
Drives: 04 Ralliart N/A, 68 Camaro
Headgasket. Causes that same issue. I would block test it. If you have any questions let me know.
__________________
Fastest Ralliart NA (Under Construction) SSP crankshaft, SSP camshaft, SSP cylinder head, SSP 14:1 pistons, SSP Flywheel, SSP twin disc clutch, soon more custom products for the drag car.
Fastest NA RA E.T. 12.7 @ 110 (Ran w/RRM products)
First RA in the 12's
Offline
Old Oct 19, 2009, 10:57 PM   #13
Thomar's Avatar
well that would be just crap if its the head gasket.
Offline
Old Oct 19, 2009, 11:14 PM   #14
Personal Sales Rating: (14)
2005 Mitsubishi Lancer Evolution
EvolNinja's Avatar
Drives: 2005 Evolution 8, DD 92 Camry
wow, after the thermostat and it still didn't fix the problem? hope you get the problem fix bro
__________________
Tomei ARMS/HKS 272s/HKS SMF Intake/ARP HStud/Mil.Spec/PTE880/Megan O2/Buschur Mani/3"TBE/Walbro/Hallman/Injen Intake Pipe/3"FMIC/Synchronic BOV/WORKS XC8
EvolNinja
Tuned by 4WS Tuning
Offline
Old Oct 20, 2009, 11:35 AM   #15
How do you bock test it? I'll kno fr sure Thursday if it's fixed now. Have to drive to my gparents an it seems to be heating when I drove there to replace my therm.
Offline
Tags
car, gauge, hot, overnight, reads, sat, temp
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
