Sep 20, 2009, 02:51 PM
Personal Sales Rating: ( 1)
Drives: Mitsubishi Prancer RalliArt, 5spd
removing the passenger and driver side window
is it too complicated to remove the front windows? say, the window got damaged but then i wanted to find a new window to replace it with. Too much trouble to do it myself?
Offline
Sep 20, 2009, 03:44 PM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
I've never done it, but it shouldn't be too terribly complicated. You'll have to remove the door panel (obviously) and the window channel weather stripping. Once that's all out of the way, you'll have to disconnect the bottom of the window from the regulator assembly, which the service manual says is only two bolts. Remove those, then use suction cups to get the glass out.
Online
Sep 22, 2009, 09:16 AM
Personal Sales Rating: ( 7)
Drives: 05 R/A
i had to do it a month or so ago, some ****s broke my window and tried to steal my radio.
anywho, its not terribly hard. as otter said, remove the door panel, remove the plastic backing either completely (removing the speaker), or partially by just folding it down. (the adhesive here gets really messy, so have some goo-gone and a nice rag ready). once you remove it all, plug the window control panel back in, as you will need it to adjust the windows in a little bit.
if you examine the door panel there are two small holes near the center area that you can fit an extension/socket through. roll the windows up/down until youve aligned the holes on the panel, with the bolts on the actual glass assembly. remove 2 bolts/remove window (will take some futzing with), reinstall, retighten, ????, profit.
take the time to shop-vac all that glass out of your door channel too (if it was broken line mine)
Online
Sep 24, 2009, 04:02 PM
i honestly got a ticket for window tint for the 2nd time and i really dont want to spend extra money removing it then putting it back on. sigh... dont know what to do, i love my window tint
Offline
Sep 25, 2009, 06:10 AM
Personal Sales Rating: ( 0)
2006 Mitsubishi Lancer
Drives: 2006 Mitsubishi Lancer Ralliart
^ thinkfree.ca
Offline
Sep 27, 2009, 03:31 PM
Drives: 2002 Lancer OZ
Just get lighter tint. Get 5% in the back it'll make the rest look darker
Offline
Tags
2001, adhesive, diego, door, driver, drivers, glass, panel, passenger, remove, removing, san, side, tacoma, window  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
