I had that issue. For the life of me I searched and could not find firm thin rubbery gasket material that suited the fix. Ended up using that 3M double-sided body tape (you can buy it at Walmart), which worked okay. Later I ordered that stock rubber gasket from the dealer that goes under the stock wing end pieces and the trunk, in case i want to put the original wing back on - for only a few dollars! Maybe you should just order those and use'em with the evo wing.
And do not tighten the trunk/wing screws too much or the wing pieces will split at the bottom near the screws!
