Jul 25, 2009, 01:40 PM
Personal Sales Rating: ( 1)
Drives: 2004 Lancer Ralliart
sputtering engine
here is a quick question that has been buggin me for about a year, everytime i start my car she idles at 500 rpm then stalls out, and if i try to rev it, itll sputter at 2500 rpm, and if i floor it it only goes to 4000 rpm wit no sputtering, any of you gurus kno wat the problem is.
thanx in advance guys
Offline
Jul 25, 2009, 07:41 PM
2005 Mitsubishi Lancer
Drives: 2005 Lancer Ralliart
Sounds like your car is in limp mode. Use a code puller to see what codes come up. You said this has been bugging you for about a year... Does your car drive normally after the initial stalling and sputtering?
Offline
Jul 26, 2009, 02:12 AM
Personal Sales Rating: ( 0)
2004 Mitsubishi Lancer
Drives: 04 RA
reset ecu by disconnecting negative terminal on battery, start up, let idle for 10 min, drive under 3k rpm for 15 min, turn off car, and see if problem persists or if CEL comes up, then pull code and post up for us to help.
__________________
[x] RRM piggyback
[x] RRM UDP
[x] RRM SRI
[x] RRM SS clutch line
[x] RRM rear strut bar
[x] 2.5 Otto Exhaust
[ ] RRM stage 2 Camshaft
[ ] RRM stage 1 clutch
http://www.cardomain.com/ride/2941543
Offline
Jul 26, 2009, 02:51 AM
i took it to advanced and they said that the computer was reading TPS and MAF was faulty, im downrange so i cant really get it fixed, lol, which is why im postin on here to see wat i could have my lil brother do (with out causein more harm to my baby, lol), the CEL is on cause my cat is cleaned out, dont ask why, my best friend thought it would be cool so he did it while i was at work, lol
Offline
Jul 26, 2009, 05:17 AM
2006 Mitsubishi Lancer
Drives: 2006 Mitsubishi Lancer Ralliart
maf can be cleaned with contact cleaner.
tps eh.. i donno how much it costs but its easy to replace.
Offline
Jul 26, 2009, 05:39 AM
Drives: Tarmack Black 2006 EVO IX MR "Black Beast", Gunmetal Grey 2007 Outlander, Octane Blue 2008 EVO GSR
Where are you at down range?
__________________
2006 Tarmack Black EVO IX MR Highly Modded 711WHP 603 TQ "Black Beast"
2007 Gun metal Grey Outlander XLS stock
2008 Octane Blue EVO X GSR Stock for now....
"Get Boosted"
Check out my website:
http://mitsubishievoix.ning.com/
Offline
Jul 26, 2009, 07:58 AM
im jus north of saudi, across the persian gulf from iran, and i cleaned the maf wit a maf cleaner, and it still had the same problem. i was hopeing its as simple as jus replacing the tps. does anyone kno where i can get a tps?
Offline
Jul 26, 2009, 08:52 AM
ok well good Luck I'm in afghanistan.
__________________
"Get Boosted"
Offline
Jul 26, 2009, 09:21 AM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Please give the specific codes if you have them. Our car doesn't have a servicable TPS. It's probably the APPS that's failed, but would need the actual code your car threw to verify.
Offline
Jul 26, 2009, 02:36 PM
Quote:
im sry i dont have this code, where is the APPS at?
Offline
Nov 6, 2009, 10:56 AM
Personal Sales Rating: ( 4)
Drives: 04 Ralliart
I'm having a similar issue, but it would seem that mine is sputtering near when MIVEC kicks in. It's feels like the engine is going to stall out on me or like a skip. It's between 2500 and 3500 RPM range. I called the Dealership and they were no help, they told me that I could bring it in and do diagnostics, but it would be better to wait until it's a real problem so they could narrow it down to the actual problem. It is a real problem. It does it in all gears, but i have to be at a steady speed. Any help?
I was thinking it could be the valves, or an injector going bad???
Upon further research, I'm being led to the idea that the problem could be a faulty coil pack??? Or a dirty or faulty MAF??
Also, there is no SEL code so I have no way of telling exactly where the problem lies except that if definitely feels like the motor isn't getting something around that RPM range or that it's binding up in that range. It's hard to describe exactly how it feels, but I think that the binding up description might be the best I have.
Reason: Amplifying information
Offline
Tags
2004, 2005, car, drive, engine, evo, idle, lancer, mitsubishi, position, ralliart, sensor, sputter, sputtering, throttle, tps  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
