Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Engine/Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory
Search
04-06 Ralliart Engine/Drivetrain (no forced induction)
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Jul 8, 2013, 10:31 PM   #1
Personal Sales Rating: (0)
Garage is empty, add now
Drives: 2004 Mitsubishi Lancer Ralliart
shift linkage bushings?
Are there replaceable bushings in the shifter linkage? When I pop my shifter into neutral it kind of sticks, won't go back to center. Wondering if its the cable or possibly bad bushings.
Offline
Old Jul 9, 2013, 06:25 AM   #2
Personal Sales Rating: (1)
rzrxn's Avatar
Quote:
If I can recall correctly, I think CRANSWICK had the same problem. I'm not sure how he fixed it but I think it had something to do with the spring/coil "thing" right under your shifter. I think we covered this here on EvoM somewhere...
__________________
Tramp -- 2004 Lancer RALLIART
(Click here to go to Tramp's thread)
-- WINGLESS --
8000k HID Headlights MOMO Shifter Knob Eonon Stereo Head Unit w/ LCD screen
Matte Black PlastiDip Emblems and Wheel Centre Caps
////// MITSU4LIFE //////
"Every good and perfect gift is from above." -- James 1:17a
Offline
Old Jul 9, 2013, 06:31 AM   #3
Personal Sales Rating: (2)
slc-ralliart's Avatar
Drives: 2004 Lancer Ralliart, 1982 BMW 320is(sold), 2006 Subaru Outback (wifes car)
There are replaceable bushing. The brass ones from speedsource for the Evo 8/9 fit perfect and are around $25.
Your problem does not sound like it is bushing related. I think Cranswick had the same problem. I believe the spring by your shifter base is likely binding.
Offline
Old Jul 9, 2013, 07:54 AM   #4
rzrxn's Avatar
+1
LOL i think we were both writing our replies at the same time b/c i swear we basically said the same thing lmfao!
"Great minds think alike"
__________________
-- WINGLESS --
Offline
Old Jul 9, 2013, 03:26 PM   #5
Thanks I will check it out
Offline
Old Jul 9, 2013, 07:02 PM   #6
Personal Sales Rating: (5)
2006 Mitsubishi Lancer
CrAnSwIcK's Avatar
Drives: 2006 Lancer Ralliart, 2003 Lancer ES
it's not the spring, it's the hinge on the selector...
__________________
2006 Lancer Ralliart Turbo
Big 16g Turbo @ 12psi (stock block) / ECU Reflash with FastWorks, Tuned by Hackish / WRX 440cc injectors / AEM short ram turbo intake / CherryBomb Turbo muffler / Blox roll stopper / ARP Head Studs / ACT stage 2 / Quaife Limited Slip Differential /
A1 CVTech Stage 1 axles / SpeedSource shift bushings / Tein S-Tech / Whiteline rear sway bar / VIS CF hood / AEM Wideband / GlowShift Oil/Boost / Dunlop ZII 205/50R16 / Enkei Wheels / Centric rotors / Hawk HPS pads
2003 Lancer ES (sold)
Offline
Old Jul 9, 2013, 10:46 PM   #7
Quote:
JUst dry? Worn out? Would I have to replace the assy.?
Offline
Old Jul 10, 2013, 06:14 AM   #8
Personal Sales Rating: (3)
mikemike396's Avatar
Drives: 2004 RA
Send a message via AIM to mikemike396
I have the brass bushing upgrades and had the issue of the shifter not going back to neutral. What I do is every couple of months I spray lithium grease on the bushings under the hood. Just a small amont goes a long way. I believe the reason they bind up is because dirt and grim gets in them. Never had that issue again, after lubing them up.
__________________
2004 Lancer RALLI//ART
EBC USR Series Sport Slotted, ECB Greenstuff 2000 Series Sport, Whiteline Swaybar, Moog Rear Endlinks, AEM CAI, RRM Cat Back, RRM UDP, Yokohama S-Drive - 205/50/16, Tein S-Tech Springs, KYB GR-2 Struts, B&M Short Throw, SpeedSource shift bushings, AEM WideBand, AutoMeter Oil Pressure
Offline
Old Jul 10, 2013, 06:37 AM   #9
rzrxn's Avatar
yea that hinge also try what mikemike suggested
__________________
-- WINGLESS --
Offline
Old Jul 10, 2013, 10:23 AM   #10
CrAnSwIcK's Avatar
chances are it's not the cable end bushings, but that hinge, you'll see on the control housing select levers the "side to side" lever there's a sort of conical plastic cap, pop that off, and there's a nut and a lock washer, pull that off, and it's probably seized in there, take the hinge apart, you may need a small hammer, try not to bend the lever, there's a split plastic bushing...clean it up, grease it, and reassemble...
__________________
Offline
Old Jul 10, 2013, 12:41 PM   #11
Awesome. I'm gonna dig into it shortly. Its driving me crazy. can't make those quick 2-3 shifts nicely. Thanks.
Offline
Old Jul 10, 2013, 06:35 PM   #12
CrAnSwIcK's Avatar
you should still also get the metal bushings, shifter base and cable ends...if you want to shift quick fix your return to center get solid bushings and then fill your tranny with redline MTL...
__________________
Offline
Old Jul 11, 2013, 06:14 PM   #13
Indeed it was the 'side to side' shift lever. Previous owner must have replaced the bushing and installed it with a lock washer and regular nut. It was clamping down too much on the bushing. Replaced them with a lock nut, left a bit of 'play' and everything is nice and loose. Thanks Cranswick.
Offline
Old Jul 11, 2013, 06:16 PM   #14
Think ill definitely consider the solid.bushings all round as well.
Offline
Old Jul 11, 2013, 06:48 PM   #15
CrAnSwIcK's Avatar
believe it or not, the plain nut and lock washer are factory...don't leave too much play or it will wear the bushings weird, and could bind...make sure to get some good quality grease in there...always happy to help
for the bushings, some one already mentioned AMS and speed source...there are a few others, but i'll recommend these, because they are local (Niagara Falls), and shipping is fast... Ziggy is a machinist and makes these in house, also his shift knobs are second to none. I advertise for him, because he's interested in supporting our platform...he stocks stage 1 clutches for our cars, and is looking into other products to carry.
https://www.rtmracing.com/xcart/prod...cat=640&page=1
__________________
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
