Oct 26, 2009, 07:05 AM
Personal Sales Rating: ( 0)
Drives: 06 lancer ralliart
ralliart 5 speed vs. evo 6 speed
ok my ? is, does the trany out of a evo 9 bolt to a 2.4 l 4g69 engine in the 06 ralliart. Also i understand that it will be a all wheel drive trany but can u not remove the transfer case making it a fwd? yes i understand this might sound silly if not stupid to some but that's not what i'm asking. will it bolt to and work as a fwd transmission?
Offline
Oct 26, 2009, 08:02 AM
Personal Sales Rating: ( 3)
Drives: 02 Lancer OZ, 06 Lancer Ralliart
With extensive mods to the tranny possible, but really a 6 peed mr tranny, wouldn't do you any good.
__________________
RALLI////////ART NATION
White 2002 O.Z. Lancer (RIP)
White 2006 Lancer Ralliart
RRM Intake Manifold, RRM Cold Air Intake, EVO 8 Spoiler, EVO 8 Gauge Cluster, EVO 7 Steering Wheel, EVO 9 SE Seats front and rear, EVO 7 Door panels.
Soon to be on the car:
RPW Stage 3 Cams, RPW Cam Gears, Piggyback unit, RPW fully coated headers + downpipe, ACCOLADE Front Bumper, Rear Bumper, Fenders, Hood, & Side Skirts.
WTB: Cerious Performance Shaven Trunk for the 04-06 Lancer. PM with any offer.
Offline
Oct 26, 2009, 08:45 AM
Personal Sales Rating: ( 29)
Drives: 2005 Mr. Evo Eight
please search as this topic has been covered many times. The amount of money you'll spend makes it not worth the trouble but hey its your car... If you're having tranny issues get a rebuild.
__________________
New to the Ralliart forum? Got some questions about your car and its compatibility? Check out the Noob Thread and you'll find a lot of your answer there!
Offline
Oct 26, 2009, 09:09 AM
ok i want to make it a awd car one of these days and put a turbo on it i just want to know can it be done and what r the down sides of the six speed ei. will i have to run different cv shafts does it have the same bell housing, ect.
Offline
Oct 26, 2009, 09:40 AM
For AWD you are going to need the tranny out of an outlander that has AWD and everything back. The EVO 6 speed is not an extra gear with power, its a gear in the middle, not good for racing.
__________________
Offline
Oct 26, 2009, 11:04 AM
now i have looked at the outlander before if i do find an awd trany will i be able to use it as a fwd till i can get all the componets for the rear and or can i just get a tranfer case and use my trany i have now?
Offline
Oct 26, 2009, 02:17 PM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
If you want an AWD turbo Ralliart, then buy a used Evo. Cheaper and more reliable.
No, you cannot put a transfer case onto your current trans, and no, you cannot install a AWD trans then run it as FWD.
As for the 6 speed, there really isn't a benefit. Slightly shorter gear ratios, which equal more shifting, but our car is already geared quite short, so the extra gear really won't help anything.
Offline
Oct 29, 2009, 05:08 PM
ok i know this might seem like a dumb ? but does the 04 05 and 06 ralliart 5 speeds have the same gear ratios
Offline
Oct 31, 2009, 01:13 AM
Drives: 2005 Lancer RalliArt
Quote:
+10
Why would you??
To my understanding, in most cases, 6th gear has been used as an overdrive to compensate for close gear ratios in 1-5th gears. Close gear ratios come in performance cars. So really, there's no point putting a MR tranny in a RA, even if it did fit. Major waste of dollaz.
__________________
I know I'm slow but I look good....
Offline
Tags
04, air, cold, evo, evo6, gear, intake, manifold, raliart, ralliart, ratios, speed, tranny, vi, vii  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
