Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Engine/Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 7, 2009, 06:22 PM   #1
Personal Sales Rating: (0)
gary_06ralliart's Avatar
Drives: 2006 ralliart
Header/downpipe install ?
With the obx or rrm header and down pipe combo is there any welding involved?? from the pic it looks bolt on, but it doesn't seem like the down pipe is long enough or has the right bends to get to the axle. thats the only place i see another flange besides the header. thanks for any help guys!!
__________________
WANTED TO BUY, HEADER AND DOWNPIPE! PM ME IF YOU HAVE ONE!
Offline
Old Oct 7, 2009, 07:49 PM   #2
Personal Sales Rating: (1)
soulesswarrior's Avatar
Drives: Lancer ralliart
the header/dp is all bolt on. it DOES NOT lead to the axel. it leads to where the cat bolts on. UNLESS your cat is not bolt on. if it is not you will have cut and weld.
Offline
Old Oct 7, 2009, 11:29 PM   #3
Personal Sales Rating: (5)
Raikiri's Avatar
Drives: 05 Pearl White Ralliart AT
he has an 06 RA though. the header/dp will bolt on and will actually eliminate your cat unless you buy a high flow cat to weld in but will bolt onto the exhaust piping
Online
Old Oct 8, 2009, 09:52 AM   #4
yes it is the 06, and i see that it elminates the cat, but it doesn't look like my cat is bolted on, i think its welded, i'll check again today be sure, but its supposed to just bolt up right after eliminating the cat? thanks again guys, i just want to be sure before i purchase
__________________
Offline
Old Oct 8, 2009, 09:54 AM   #5
yes its supposed to bolt to the flange right after the cat. so if you have a welded on cat you will have to cut out the cat and throw on a flange. id also reccomend rrm over obx.
Offline
Old Oct 8, 2009, 12:28 PM   #6
Raikiri's Avatar
a welded on cat? did something happen to the oem one? if everything is stock on the car the cat should already have a flange that bolts to the exhaust piping. that just needs to be removed. i also would recommend rrm over obx
Online
Old Oct 8, 2009, 01:04 PM   #7
i think the 06 ralliarts came with weld on cats.
Offline
Old Oct 8, 2009, 06:27 PM   #8
Silverbolth's Avatar
Drives: Lancer Ralliart 2006
Well I have an '06 ralliart and it does have a flange after the cat...
__________________
-Zaklee torque damper / clear anodized underhood shifter bushings
-B&M short shifter /with energy suspension bushings
-Injen cold air intake
-Ultimate-Racing CatBack
-RRM rear strut bar
-H underbody brace
-Depot black taillight
Tomorrow is easy because it hasn't happend yet. Yesterday is painful because it lives on forever
Offline
Tags
08, 2009, cost, downpipe, flow, hard, header, headers, install, installing, lancer, obx, oem, ralliart, weld
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
