Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Engine/Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 16, 2009, 12:17 PM   #1
Personal Sales Rating: (0)
RalliartPro's Avatar
Drives: 2004 Ralliart Demon
Engine running lean
The other day I just put on a new intake manifold gasket and a oil cooler. Turn on the car which has oil at full mark and is running lean on 17 & 18. Just to check I took the oil cap off and to see if oil is flowing around but sees everything dry. Shouldn't there be oil shooting out if you take the oil cap off?
__________________
Current Mods: RRM SRI, RRM P&P intake manifold, RRM camshaft, RRM piggyback, RRM underdrive pulley, RRM motormounts, STM balance shaft eliminator kit, Evo big bore fuel rail, Megan fuel regulator, Walbaro fuel pump, OBX headers with zeitronix ZT-2, 2.5" midpipe, CXRacing Evo radiator, Tein suspension, RRM slotted rotors, Rota Racing Grid 18x8.5 with Yokohama S drive 215/40.
In 1 month: GT35R Turbo with pistons and rods.
Offline
Old Aug 16, 2009, 07:42 PM   #2
Personal Sales Rating: (1)
2009 Mitsubishi Lancer
RotorGlow's Avatar
Drives: 2009 Lancer Ralliart Sportback
Nope...might get a drop or two come out...
__________________
- Tuned by TTP Engineering
- CP-E QuickPower pipe
Offline
Old Aug 17, 2009, 08:22 AM   #3
Send a message via ICQ to hackish Send a message via MSN to hackish Send a message via Skype™ to hackish
Make sure you hooked up the oil cooler correctly. I've seen them hooked up backwards and they basically block the oil flow enough that your engine gets a few psi of oil pressure and that's it.
-Michael
__________________
One reflash can do what 5 different piggybacks cannot.
Offline
Old Aug 17, 2009, 10:00 PM   #4
Well it seems there is only one way to put it on with the rubber seal on the adapter going to the engine and the filter to the adapter and the the hoses to the adapter. I figured I would see the oil circulating if I took off the oil cap, regardless that wouldn't have anything to do with the lean condition. Right now I'm checking o2 sensor and all other connections.
__________________
Offline
Old Aug 18, 2009, 10:45 AM   #5
If you reset your ECU (unplugged the battery) that can often wreak havoc on piggybacks and the learned fuel trims. I suggest consulting your tuner. Also, make sure you're using an accurate means of determining if you're lean or not - ie a wideband.
-Michael
__________________
Offline
Old Aug 18, 2009, 08:54 PM   #6
I don't have a tuner and I use zeitronix wideband for afr. Even so I'm gong to change the computer and get it dyno tuned when I put turbo in my car. As for my oil pressure I guess I should look into a gauge to make sure.
Would a small leak between the intake manifold and engine cause the lean afr?
__________________
Offline
Old Aug 19, 2009, 10:11 AM   #7
Yes a small leak at the intake manifold can cause the problem. In that case you will probably see your idle short term fuel trims going up until it hits 14.7. The ralliart has a lot of authority on adjusting fuel trims. I saw a car the other day idle at stoich with the stock ECU and RC 500cc fuel injectors. This was before reflashing obviously but it gives you an idea of what level of adjustment is possible with just the stock O2.
__________________
Offline
Old Aug 19, 2009, 12:42 PM   #8
I'll just wait for my car to get out of the shop so that I can back track what I did and hopefully do it right. I appreciate your help hackish.
__________________
Offline
Tags
car, drive, engine, evo, intake, leak, lean, manifold, means, race, ralliart, running
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
