Aug 6, 2009, 10:05 PM
Personal Sales Rating: ( 0)
Drives: 2004 mitsubishi lancer ralliart
engine cutting out
its only done it about 4 times now but sometimes if im pullin hard around 5000
it cuts a very noticable amount of power but then starts pullin hard again.
has anyone else had this prob
prob just needs a tune up prob wouldnt hurt ive put around 20,000 on the car and the plugs probably havent ever been changed
Offline
Aug 9, 2009, 06:21 PM
Drives: 1991 Mitsubishi Eclipse gs-t
your plugs should be good for another 40k miles along with everything else for a tune up....do you have a boost controller on it?
Offline
Aug 9, 2009, 08:01 PM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
I'm willing to bet that, if you haven't already replaced it, its accel pedal position sensor.
Offline
Aug 9, 2009, 11:18 PM
2004 Mitsubishi Lancer
Drives: 04 RA
Quote:
this, but also listing any mods you've done would be helpful!
__________________
[x] RRM piggyback
[x] RRM UDP
[x] RRM SRI
[x] RRM SS clutch line
[x] RRM rear strut bar
[x] 2.5 Otto Exhaust
[ ] RRM stage 2 Camshaft
[ ] RRM stage 1 clutch
http://www.cardomain.com/ride/2941543
Offline
Aug 9, 2009, 11:37 PM
the car has 88,000 but i put 20 of them on it
so i changed my oil not even a month ago and i checked my oil today (the car dosent smoke at all and dosent leak a drop NONE WHATSOEVER) it was three quarts low dont ask how it isnt blown up. any way im gussing it didnt have enough oil pressure to fully engage mivec ??? but it has to be burning oil because its not leaking any my cat stinks when i turn the car off too.
does it have a boost controller? no because its not boosted
what mods?
4-1 header stainless downpipe (OBX)
cai
thats it
Offline
Aug 9, 2009, 11:59 PM
If you've lost 3 qts you've got much bigger issues. If you're not mechanically inclined it's time to find a mechanic.
Offline
Aug 11, 2009, 05:23 PM
im very mechanically inclined but
tell my what u think
no water in the oil, or oil in the water
no smoke ever
no leaks at all
oil light isnt even coming on
no lifter tick no abnormal noise at all
dosent make sence
Offline
Aug 11, 2009, 06:20 PM
Personal Sales Rating: ( 1)
Drives: 04 Ralliart N/A, 68 Camaro
did you add the proper amount of oil into the engine? I have to ask this. Also what is your crankcase pressure? Should be under a vacuum when running but positive pressure can cause some issues. If you did add the proper amount of oil it went somewhere either out the tail pipe/ internal leak, or external leakage.
__________________
Fastest Ralliart NA (Under Construction) SSP crankshaft, SSP camshaft, SSP cylinder head, SSP 14:1 pistons, SSP Flywheel, SSP twin disc clutch, soon more custom products for the drag car.
Fastest NA RA E.T. 12.7 @ 110 (Ran w/RRM products)
First RA in the 12's
Offline
Aug 11, 2009, 07:17 PM
What SSP said. First thing I'd do in that situation is a leak down test. Figure out if the rings or valves are letting an excessive amount of oil by.
Offline
Aug 14, 2009, 05:58 PM
Drives: 2004 Mitsubishi Lancer Ralliart
i kind of have the same issue with mine, but my oil level is fine. its not at 5000 though either. its when i have my cruise set between 60-70 every once in a while it will... lurch? i guess would be the word. i can feel the power just go away and come back. its like i push the clutch in and let it back out real quick, minus the jerkiness.
it's enough to make me lean forward and then push me back in my seat a little bti
Offline
Tags
2009, 24, clutch, cuttin, cutting, eclipse, engine, lancer, mitsubishi, pedal, position, ra, sensor, tick  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
