Jun 17, 2009, 07:18 PM
Personal Sales Rating: ( 0)
2004 Mitsubishi Lancer
Drives: 2004 Lancer Ralliart
oil temp guage install leaking help
so as a result of the issues i have been having with my oil system i decided to install a oil pressure and temp guage. the temp guage came with a variety of drain plug sizes. i found the one that matched my RA and everythong went fine. after my first test drive i parked it and left it when i came back some time later there was a oil puddle under the drain hole it was not hudge but big enough. the problem is the fitting is brass and im afraid to tighten it down to much. i put teflon on the threads before the install. does anyone know where i can buy a new steel fitting that still has the hollow center for the thermometer? what is everyone else using? i cant see using this brass piece and taking it out every oil change its going to break at some point. thanks for the input.
Offline
Jun 17, 2009, 07:23 PM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Which hole did you use and did you use a BSPT adapter or NPT?
Offline
Jun 17, 2009, 07:36 PM
i put it in the oil drain hole. as for bspt or npt not sure i used the hardware that came with it i do know there was no stripping of the threads so i assumed it was correct maybe not
Offline
Jun 17, 2009, 08:02 PM
Ah, if you put it in the oil drain hole, did you use a new crush washer?
Offline
Jun 17, 2009, 08:37 PM
no i did not that might be my problem should i move it to a different location or will the crush washer fix the problem? i realy dont want to keep taking that out for each oil change? where are the other places i can put it?
Offline
Jun 18, 2009, 02:16 PM
Drives: 2004 Lancer RalliaArt
You should not put a steel fitting into the aluminum block it makes it to easy to mess up the block. as for the crush washer thats a key parts but you could also just use quick dissconnect fittings to insure it wont leak and for removability. you can put it onto the back of the block under the intake manifold, you can ether T off the oil light sensor or jsut unplug the sensor for the oil light and put your fitting in the hole from oil light sender switch.
opps sry i was refering to the pressure gauge leaking. but i suppose you could just T off the oil light for that to.
Offline
Jun 18, 2009, 08:41 PM
thanks for the reply guys. I went up to the local mitu dealer and picked up a crush washer. put it on there making sure not to tighten the brass fitting to much. Seems to be leak free now. thanks again.
Offline
Tags
04, 0il, 2004, evo, gauge, guage, install, lancer, leaking, leaks, mitsubishi, oil, pressure, ralliart, sensor, temp  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
