Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Engine/Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 18, 2009, 06:18 PM   #16
Personal Sales Rating: (5)
Raikiri's Avatar
Drives: 05 Pearl White Ralliart AT
to my understanding you need to place the cat after your first o2 sensor in the downpipe and before the o2 sensor in your exhaust tubing so really the only place you can cut out is the downpipe unless there's room in the exhaust tubing before the o2 sensor
Offline
Old Jun 21, 2009, 02:57 PM   #17
Personal Sales Rating: (1)
soulesswarrior's Avatar
Drives: Lancer ralliart
also for the leak, you may want to try some of that red silicone high heat gasket maker?
Offline
Old Jun 21, 2009, 09:12 PM   #18
Personal Sales Rating: (0)
benny_ralliart's Avatar
Drives: '05 Lancer Ralliart
Send a message via MSN to benny_ralliart
Quote:
Hmmmmm that might be my problem, cause i jsut had my rrm header/downpipe installed and my cel is on, and ive got the cel eliminator in the downpipe.
Ive got rrm header/downpipe then a little bit of tubing then the HF then custom exhaust with a resonator and a Apexi WS II muffler. The power is definitly great but my cel is on
K so I just read in another thread that if you have the hf cat you dont need the cel eliminator is this true? Rock can you confirm this?
Thanks
__________________
Mods:
Alpine sound system
compustar 2 way alarm/remote start
red calipers
debadged
17" BSA 363 rims, with Nexen N3000 tires
Injen CAI
RRM header/downpipe
Custom Exhaust with Apex'i WS II muffler
RRM UDP
Offline
Old Jun 21, 2009, 11:17 PM   #19
Raikiri's Avatar
i have the hf cat and still have a cel... have tried the antifouler method in order to get rid of the cel but still no luck... its an on and off kind of thing
Offline
Old Jun 22, 2009, 09:32 PM   #20
dang, that light is anoying
__________________
Mods:
Alpine sound system
red calipers
debadged
Injen CAI
RRM header/downpipe
RRM UDP
Offline
Old Jun 25, 2009, 08:32 PM   #21
Drives: 2004 mitsubishi lancer ralliart
will the hf cat get rid of the CEL?
Offline
Old Jun 25, 2009, 09:22 PM   #22
05lanceralliart's Avatar
Drives: 05 Lancer Ralliart
do you always have to cut your wires for you 02 sencer to lengthen it?
__________________
Its got EVO blood!
Offline
Old Jun 25, 2009, 09:38 PM   #23
Personal Sales Rating: (3)
BlackRaven's Avatar
Drives: '05 Turbo RA
That's weird...that's what I did and it worked for me Not that it should totally matter, but I have a Vibrant HF cat, looks shorter than the pictures of the RRM/Magnaflow one.
A lot of the "directions" said you need to use two of the anti-foulers, I ended up using only one, and it hasn't tripped the light yet...and that's with plenty of typical turbo backfiring too!
Offline
Old Jun 25, 2009, 09:48 PM   #24
Raikiri's Avatar
Quote:
what?? why would you need to cut wires? there is more then enough slack on that thing
i used 2 anti-foulers so i have no idea what went wrong with mine. I tried resetting the ECU but it doesnt work for me so I'm not sure. maybe its just the air pressure or something i dont know... it went off for a while but after i cleared the code from the ecu the light came back on, so I just cleared it again so we'll see what happens
Offline
Old Jun 25, 2009, 10:28 PM   #25
Personal Sales Rating: (12)
ottomatic's Avatar
Drives: MR IX
benny ralliart: umm the check engine light eliminator goes on your midpipe after the high flow cat if you have one, not the downpipe. It goes on your second o2 sensor to lessen the oxygen and or hydrocarbon readings.
__________________
An intoxicated Red
**There's a limit to how good your life can get, but there's no limit to how much worse your life can be.**
Offline
Old Jun 26, 2009, 12:21 AM   #26
Drives: 2004 lancer ralliart
Is the hole that you drilled in your anti-foulers 1/2" and centered? I would guess that people are having trouble with this mod due to not drilling this out correctly. (assuming that everything else was done correctly) I used 7/16" to insure a tight fit with limited air flow... although I did have to route it out a bit.
300 miles on my CEL elim. mod and no light. btw.
Offline
Old Jun 28, 2009, 08:45 PM   #27
Quote:
Ive only got one O2 sensor though, so i dont have anywere else to put it
__________________
Mods:
Alpine sound system
red calipers
debadged
Injen CAI
RRM header/downpipe
RRM UDP
Offline
Old Jun 28, 2009, 10:26 PM   #28
Raikiri's Avatar
Quote:
thats not possible. I have an 05 RA too and you have an 02 sensor in your downpipe and one in the exhaust pipe. the eliminator goes into the furthest o2 sensor from your engine
Offline
Old Jun 29, 2009, 08:32 PM   #29
well i crawled under my car tonight and i found my 2nd O2 sensor, it was hiding on the other side of my cat and it looks like the CEL eliminator is on there, so now i really dont know why my cel is on. Ill have to try maybe putting it on the first O2 sensor or maybe try running with out it and see it I can get it to stay off.
Thanks for the input
__________________
Mods:
Alpine sound system
red calipers
debadged
Injen CAI
RRM header/downpipe
RRM UDP
Offline
Old Jul 16, 2009, 07:13 PM   #30
Drives: Lancer Ralliart 06
well I got my RRM DP with high flow cat installed yesterday
I also had the RRM CEL eliminator thingy pluggued on the last 02 sensor
Today I now have a CEL on my dashboard
I'll try the 2 spark plug fooler solution to see if it works better but I'm dissapointed to see the optionnal 20$ solution RRM provides doesn't even work!
Offline
Tags
363, bsa, downpipe, galant, header, headers, help, lancer, pipe, purpose, quiet, ralliart, rims, rrm, vr4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
