Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Engine/Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 10, 2009, 11:16 PM   #1
Personal Sales Rating: (0)
Send a message via ICQ to hackish Send a message via MSN to hackish Send a message via Skype™ to hackish
Another reflash feature for those running boost...
Added another feature. Boost cut. The purpose is to save your engine in the (fairly common) event that your wastegate or associated vaccum line fails. I've saved countless honda engines with this. If the boost goes above a pre-set level the engine cuts until the boost drops back down. Saves the engine from overboosting.
Unfortunately the factory MAP sensor (MDP I think they call it) is only able to sense 120kpaa so that's about 2psi of boost. So I had to replace the factory sensor with a piece I machined with a nipple and sorry guys a HONDA MAP sensor - that's all I had laying around at the time. I would prefer a plug and play solution to it but it's still in the beginning stages.
Anyone know of a compatible sensor that's a plug and play upgrade?
-Michael
Offline
Old Jun 10, 2009, 11:47 PM   #2
Drives: Ralliart Thunder grey TURBO
Probably an evo/eclipse map will work, if not then an aftermarket map would do the trick, just send a disclaimer with the available MAP sensors compatible with the flash and let the customer figureout the instalation.
__________________
Got Boost.? Member 300+whp Club & Stock Internals..!
Offline
Old Jun 11, 2009, 04:32 AM   #3
The older talon ones look like they have the same plug but I think they're a 120kpa unit as well. So far I've checked the evo 8 and 9 and they also seem to be 120kpa. The trick would be to find one that has the range and the proper plug.
-Michael
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
