Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Engine/Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 10, 2009, 08:44 AM   #1
Personal Sales Rating: (0)
Send a message via ICQ to hackish Send a message via MSN to hackish Send a message via Skype™ to hackish
Might have a solution for you dim lights UDP guys...
In the wee hours of this morning I happened to find an interesting setting in the ECU. It looks to me like it's the alternator load table. As the voltage drops the duty cycle goes up. I will be testing this tomorrow when I have access to the test mule but it looks like I can simply bump the alternator duty cycle for low RPMs and have your alternator produce more juice at idle. I spoke to an alternator guy and he doesn't feel that a mild adjustment there will cook any of the components. Once the settings are verified on the test mule I'll see if I can find a local UDP user and figure out the new settings.
-Michael
Offline
Old Jun 10, 2009, 10:00 AM   #2
Personal Sales Rating: (7)
Fifty's Avatar
Drives: 2004 Lancer Ralliart
^Am I the mule? My ego is hurt Michael!
__________________
Nick
Offline
Old Jun 10, 2009, 10:46 AM   #3
No, Brent is the mule. Looking at his oversized football player physique you can guess why I call him a mule.
Do you happen to have the UDP and dim lights problem? The mule is coming in earlier - this afternoon so I'm going to try turning off his alternator at idle and see. For you I think the launch control feature is fixed.
-Michael
Offline
Old Jun 10, 2009, 11:17 AM   #4
Fifty's Avatar
Ah that does make more sense. Brent is a big boy.
No, I don't have the UDP sorry.
__________________
Nick
Offline
Old Jun 10, 2009, 10:52 PM   #5
Sorry guys, I tried to coax more amps out of an alternator but it just won't do it. I'm guessing a simpler strategy is to just raise the idle speed.
-Michael
Offline
Old Jun 12, 2009, 12:19 AM   #6
EvoM Moderator
Personal Sales Rating: (2)
Myszkewicz's Avatar
Drives: '04 Lancer Ralliart, '82 Honda Nighthawk, '82 Suzuki GS1100, '81 Suzuki GS1100, '74 Volkswagen Bus
Send a message via AIM to Myszkewicz Send a message via MSN to Myszkewicz
My solution was to install HIDs.
Offline
Old Jun 12, 2009, 05:34 PM   #7
Personal Sales Rating: (1)
soulesswarrior's Avatar
Drives: Lancer ralliart
i started to have the dimming but then my battery kicked out new battery solved it :P
Offline
Old Jun 13, 2009, 07:29 PM   #8
I tried ramping the duty cycle on the alternator but it didn't make any difference. Changing the idle speed will but I still have to figure out how
-Michael
Offline
Old Jun 14, 2009, 01:15 AM   #9
2004 Mitsubishi Lancer
joeyj's Avatar
Drives: 04 RA
have you thought about trying to emulate the signal telling the ecu that the a/c is running? I have absolutely no idea if this will work, but i do notice that without a/c i idle at 650-700 rpm, and when i switch the a/c on it idles at 850-1000 rpm. So would it be possible to tell the ecu that the a/c is running without it on so it runs the engine higher?
or tap a line onto the rheostat then to a switch so that only when the lights are on will the switch activate and tell the engine to idle higher, granted I have no idea where you'd hook that up ono the ecu, you're the programmer not me.
I'm just spit balling here.
__________________
[x] RRM piggyback
[x] RRM UDP
[x] RRM SRI
[x] RRM SS clutch line
[x] RRM rear strut bar
[x] 2.5 Otto Exhaust
[ ] RRM stage 2 Camshaft
[ ] RRM stage 1 clutch
http://www.cardomain.com/ride/2941543
Offline
Old Jun 18, 2009, 05:43 AM   #10
That's a good idea. You could change your AC switch to interrupt or not interrupt the clutch signal for the AC compressor - you'd need a relay or larger switch. With the AC "off" it would still tell the ECU the AC was on and put a known resistance across the AC clutch line so the ECU doesn't catch your foolery. With the AC on you could direct the power to the AC clutch so it operates normally. Since I find these things take equal cost in labour I just like to solve them digitally in the programming but your idea could work.
-Michael
Offline
Old Jul 11, 2009, 02:15 AM   #11
Drives: 06 lancer RA
i found upgrading my wiring from alternator to battery, battery to chasis ground and battery to engine l ground ine to 4 gauge audio wire helped my voltage dips with my UDP and stereo system... its doesn't dip nearly as bad now, at idle i'm at about 13.5 volts, 14.5 once i'm on the gas
__________________
stuff for sale http://forums.evolutionm.net/showthr...87#post5118187
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
