Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Engine/Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 1, 2009, 02:21 AM   #1
EvoM Moderator
Personal Sales Rating: (8)
2004 Mitsubishi Lancer
GearDownSon's Avatar
Drives: a boosted Ralliart ;)
Throwout bearing?
I had read in another thread about the car making noise when the throwout bearing is going out. Mine does this. When i put in a ACT stage 3 clutch it didnt come with a throwout bearing and the one in it looked ok so i just threw it in. That was about a year and a half ago. Now it is getting very difficult to go through the gears when i am driving.Especially when the tranny heats up. It doesnt grind but it is VERY notchy. What i am wanting to know is could this be a side effect of a throwout bearing going bad?
__________________
RRM ralliart turbo self installed.
Dont hesitate to PM me with any questions an i will do my best to help ;)
Please read through the rules if you have any questions or doubts about your post.
http://forums.evolutionm.net/evom-an...uncements.html
Quote:
Originally Posted by HobieKopek
You'll be fine. You just may feel sore for a while. I bled for 3 days (not much, but enough to taste like I had a mouth full of pennis), but I also had Percoset (sp?) which meant I had a pretty good time.
Online
Old May 1, 2009, 09:27 AM   #2
Personal Sales Rating: (29)
Drives: 2005 Mr. Evo Eight
Send a message via AIM to bruce988jl
I don't know about you but when my shifting got notchy it wasn't the throw out bearing. What type of noise do you have. If its a light chattering that goes away when you push the clutch pedal down it might not be the TOB... when I did my clutch I replaced the TOB and it started to chatter immediately, then did the same when i replaced it while rebuilding the tranny...
The notchy shifting I had was from the dreaded synchro's... I had to replace the first, second and also had to replace the 2nd gear and sliding straight cut gear. Also replaced rev and the synchro to be on the safe side. 2200$ and 3 months later... minty tranny :-) and a car thats still only worth like 7K... :-(
__________________
New to the Ralliart forum? Got some questions about your car and its compatibility? Check out the Noob Thread and you'll find a lot of your answer there!
Offline
Old May 1, 2009, 02:59 PM   #3
EvoM Super Moderator
Personal Sales Rating: (10)
2009 Toyota Tacoma
My Garage
otter's Avatar
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Send a message via AIM to otter
It's possible that your clutch isn't fully disengaging. Inspect your master/slave clutch cylinders for leakage. If they're fine, bleed the clutch line so you're sure there's no air in there. You might also need to adjust your clutch pedal a bit.
__________________
READ EVERYTHING IN THIS LINK BEFORE PM'ING ME ABOUT WHY YOU CAN'T POST IN THE CLASSIFIEDS!!!
Problem with a post or thread? Use the report post button, it's faster than PM'ing a single Mod.
Read and obey the rules to help keep this forum a great place!
My Ralliart
Michigan Evo/Lancer club
Offline
Old May 1, 2009, 03:08 PM   #4
Personal Sales Rating: (0)
1998 Mitsubishi Eclipse
My Garage
GPTourer's Avatar
Drives: '05 WW CT9A GSR SSL, '98 NW D32A
Send a message via AIM to GPTourer
Quote:
Actually that symptom is a clear sign it is the TOB. In the DSM world it is a given to ALWAYS use the OEM Mitsubishi TOB when doing a clutch. I'm sure the same applies for Evos. With that said, a heavy duty clutch can sometimes have noise regardless and chatter even with the stock TOB as it wears.
But yeah, if you're having trouble going through the gears check for leaks and hope its that and you don't need a rebuild.
__________________
Skeet
Driven to Thrill
Offline
Old May 6, 2009, 01:13 AM   #5
Personal Sales Rating: (2)
Jokiesmurf's Avatar
Drives: "The Beast" 04 TURBO Ralliart
I have a ACT T.O.B laying around. Mine didn't come with one I got it thinking I need to replace. But I had to replace the whole clutch, pressure plate (Half of teeth missing) & all. I down grade my clutch to a stage 1, got it from ACT it brought every thing. so if u need it let me no.
__________________
Want to open the present I got you Ha Ha Ha
http://www.cardomain.com/ride/2551528
"The Beast"2004 Turbo Ralliart ( sun & sound package)
welded on Muffler
Offline
Old May 6, 2009, 06:52 AM   #6
I have had 2 OEM mitsu TOB's and they still make the whirring sound when the car is on almost 100 miles after starting the breakin period... I've gotten used to it and have assumed that its normal. haha
__________________
Offline
Tags
act, bad, bearing, dsm, duty, evo, evolution, galant, heavy, noise, throw, vr4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
