Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Engine/Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 19, 2009, 07:52 AM   #1
Personal Sales Rating: (2)
wake's Avatar
Drives: Lancer RAlli//art 2006
Got 5 CEL codes
I got 5 codes when I plugged my CAN OBD2 car reader yesterday and would like you to help me with that stuff.
P0100: Mass or volume air flow circulation malfunction
P0110: Intake air temp (AT) circuit malfunction
P0115: Engine Coolant Temperature Ciruit Malfunction
P0120: Throttle/Pedal Position Sensor/Switch A Circuit Malfunction
P1600: Serial Communication Link Malfunction
My car don't run in limp mode...he's jump taking more gas!!
Does anybody can help me with that?
My car is a 06 RA and here are my mods :
SRI injen with K&N filter
Engine damper
custom downpipe with a high flow cat
RRM axel-back
RRM underdrive pulley
TWM short shifter and shifter bushings
__________________
2006 thunder gray Mitsubishi lancer Ralliart with some mods!!!
Offline
Old Mar 28, 2009, 10:47 AM   #2
wake's Avatar
Nobody has an idea?
__________________
Offline
Old Apr 1, 2009, 08:40 AM   #3
Personal Sales Rating: (1)
SSP-Ralliart's Avatar
Drives: 04 Ralliart N/A, 68 Camaro
Engine damper
RRM axel-back
There may be a fault in the ECM. Considering all those devices recieve and send out information to the ECM. Maybe even a wire shorted to ground or even a bad ECM ground hard to say. You can find out what each diagnositic procedure is for each code but more then likely they are caused by 1 problem. I may be able to help ya but i also don't know how good your electrical diagnosis is. First i would find out what the diagnosis is for these codes and go from there. If you have any questions feel free to give me a buzz.
__________________
Fastest Ralliart NA (Under Construction) SSP crankshaft, SSP camshaft, SSP cylinder head, SSP 14:1 pistons, SSP Flywheel, SSP twin disc clutch, soon more custom products for the drag car.
Fastest NA RA E.T. 12.7 @ 110 (Ran w/RRM products)
First RA in the 12's
Offline
Old Apr 1, 2009, 09:53 AM   #4
wake's Avatar
With what you're saying, I think I'll go to the dealer and see what they think of it!!! It should be on the waranty so I'll see!
__________________
Offline
Tags
built, cel, code, lancer
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
