Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Engine/Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 7, 2007, 09:36 PM   #16
EvoM Moderator
Personal Sales Rating: (2)
Myszkewicz's Avatar
Drives: '04 Lancer Ralliart, '82 Honda Nighthawk, '82 Suzuki GS1100, '81 Suzuki GS1100, '74 Volkswagen Bus
Send a message via AIM to Myszkewicz Send a message via MSN to Myszkewicz
Quote:
Originally Posted by DangerousDan View Post
Anyone else with a custom tune? No one wants to play with the software? I am still only making minor changes until I have the wideband stuff, I don't want to hurt the car. Anyone else messing around yet?
One of these days I'll get another laptop I can use for logging/tuning. My old Toshiba Satellite finally croaked, so I'll either have to borrow the Compaq laptop I gave my brother or buy my own. Someday...
Offline
Old Feb 24, 2007, 04:50 PM   #17
Personal Sales Rating: (8)
Drives: your mom crazy with my striking good looks
I got the innovate motorsports lc-1 wideband kit this week. I will be installing it at the same time I install a new resonator. The only thing I need is another serial to usb connection and I'm good to start tuning. I bought a welder too no more paying a muffler shop to do my welding.
__________________
wtb 4g69 bottem end. pm me.
Offline
Old Mar 5, 2007, 07:50 AM   #18
Welded the bung, but it deformed due to the heat and I can't get the plug out, let alone the sensor in. I guess I will be replacing the factory O2 sensor, probably at the end of this week.
__________________
Offline
Old Mar 10, 2007, 10:15 AM   #19
Installed the wideband. The map I created mathematically was ok, but I could go leaner up top. The RRM map was very lean on my car. Remained around 16 and only went down to the high 14's at it's lowest. I still need to get a second serial to USB cable to run the piggy and AFR at the same time, but only to speed up tuning. For now, here is the second round of tuning with the wideband. I will post up the AFR curve for this map after some testing today.
__________________
Offline
Old Mar 10, 2007, 11:28 AM   #20
Personal Sales Rating: (1)
qlitv's Avatar
Drives: Ralli
Send a message via MSN to qlitv
With what mods are you tunning your Piggyback?
Offline
Old Mar 10, 2007, 02:09 PM   #21
Personal Sales Rating: (6)
ralliart329's Avatar
Drives: 08 Mazdaspeed3 GT, 04 RA SOLD
i dynoed my car today and my AFR was low 14's, but i dont have a wideband to tune it. what was your AFR before and after, bc if it is close id think about plugging your map in until i can get mine tuned at a shop since yours is a little richer.
Offline
Old Mar 10, 2007, 09:43 PM   #22
My AFR's with my mathematical map stayed below 15 in all parts and averaged low 14's. Dipped into the 13's a bit here and there. The RRM map way very lean, averaging around 16 and staying above 14 the whole time. I would recommend the latest map, it has gotten me consistently in the low 13's all across the powerband. It needs some adjustment, mainly to compensate for the Mivec changeover, but I am pretty happy with the results. I can suggest some differences for you as well, so pm me if you want.
I will be doing some minor changes to this map, and then to the dyno to test all my maps. I want to compare the mathematical map, the RRM map, the stock ECU map, and my tuned AFR map. Anyone want to venture any guesses?
__________________
Offline
Old Mar 11, 2007, 06:16 AM   #23
the tuned map will be best. rrm did a good job but every car is different and different mods etc. for the math map it works on paper but doesnt always in the real world.
^typing you a pm now.
Offline
Old Mar 11, 2007, 08:35 AM   #24
qlitv's Avatar
Drives: Ralli
Try my map in the dyno my afr was 13.99 I post it earlier in this thread
Offline
Old Mar 11, 2007, 08:37 AM   #25
what were your mods when you dynoed it?
Quote:
Offline
Old Mar 11, 2007, 08:54 AM   #26
qlitv's Avatar
Drives: Ralli
injen cai, ud pulley, rrm downpipe, rrm exhaust, s/s clutch line and of course the piggy
Offline
Old Mar 11, 2007, 08:58 AM   #27
qlitv's Avatar
Drives: Ralli
But as i said earlier the guy didn't tuned like it sais in rrm he did it with the aditional injector and gauge pressure
don't know if that make a diference in hp or afr
im waiting on a p&p IM and a ported throtle to go tune again with a custom header like rrm's
and tune it right with the prog calibrator and volts
Offline
Old Mar 12, 2007, 10:19 AM   #28
That's no lie. I am at work or I would post all the images I have but I can't contain myself
The tuned map is about as close to perfect as I can imagine getting to. I am going to buy the tactrix cable and evoscan so I can log all my information on one graph, but I am not sure if I will be able to improve the map. 2nd, 3rd, 4th and 5th gear all average 13.3 AFR, maxing out at 14.7 or less and going down to the very high 12's at the richest. 1st gear is still kind of lean, but I think that's because I spend less than two seconds in gear and the AFR doesn't have time to level off. It still doesn't go above 15 unless I am off the throttle(duh.) Looking at the graphs I am in the low 6's to 60, but I may be able to get a more accurate idea once I start logging to evoscan instead of logworks. I am also unsure of the AFR for the entire rpm range for 5th gear, there aren't too many places to do 136mph around here so I had to settle for 5500RPM's
ralliart329, I am going to work on your stuff when I get home too, is the map you emailed me the map the AFR's came from?
__________________
Offline
Old Mar 12, 2007, 10:41 AM   #29
qlitv's Avatar
Drives: Ralli
Is the map that you posted the one that is close to perfection?
what mods do you have?
Offline
Old Mar 12, 2007, 02:25 PM   #30
yes it is. i uploaded that map off the ecu and emailed it from my car. Again thanks for doing this. is the evoscan and new cable replacing the system you have in place now? if so im in the market for some tuning tools.
EDIT: i dont hit 136 often either so you dont have to go to the track just for my map
Offline
Tags
1381, 4g69, afr, airfuel, back, calibrator, idle, karmen, lancer, maf, map, maps, piggy, piggyback, psc1004, rallisrt, tuning, turbo, wrx
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
