Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Engine/Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 26, 2005, 08:06 PM   #1
Personal Sales Rating: (1)
sillypuddy's Avatar
Drives: 2004 RA Silver
safc ii
I am tired and I am at my wits end.. throwing in the towel for tonight until I can call Apex-i tomorrow and hopefully (doubt it) they can help me with the install
i got all the wires hooked up to the right wires, etc..
but these sensor type does not work..
00 00
01 01
11 11
I didn't want to go and try all 99 combinations...
-joe
Offline
Old May 26, 2005, 11:28 PM   #2
Personal Sales Rating: (9)
Arithmetic's Avatar
Drives: 2004 Infiniti G35 Coupe and 2004 Mitsubishi Lancer Ralliart
Send a message via AIM to Arithmetic Send a message via Yahoo to Arithmetic
i feel your pain, ive been holding off on buying the s-afc until somebody actually post up a "how-to". It's like people know, but don't wanna say anything...
__________________
2004 LBP Ralli//Art
HKS | GREDDY | RRM | ACCOLADE | NSC | APEXi
| Video: Greddy Evo 2 Revv |
- do you MIVEC daily?
RSR Vol.3 Is Coming!
Offline
Old May 27, 2005, 05:10 AM   #3
sillypuddy's Avatar
most people got it installed at their local tuners..
i will get it working sooner or later.. it's all part of figuring things out instead of just waiting for the answers
-joe
Offline
Old May 27, 2005, 06:33 AM   #4
Personal Sales Rating: (2)
blk-majik's Avatar
Drives: 08 RR Evo X GSR
what sensors do u need to konw?
Offline
Old May 27, 2005, 06:40 AM   #5
sillypuddy's Avatar
let's sum up what we know so far
people who got it installed at their tuners does not know how it's wired in (apexi doesn't have a diagram for our car).. so that part we are all guessing at right now until we get a DIY together..
I can confirm that I got the RPM, throttle position, knock, power, mas sensor and ground wires connected to the right place, but it just won't start when I have the safc plugged in.. I have tried the same unit on another car and it works fine
for the initial setup, the sensor type and sensor no. and stuff in the "etc.." menu .. i was told that it is
hotwire
sensor type = 01 01
sensor no. = 1 1
or
hotwire
sensor type = 00 00
sensor no. = 1 1
I called apex-i before.. don't even bother calling them for "support" since all they do is tell you to ..
get a service manaul
figure it out yourself
or pay somebody to do it
if you ask them any technical questions (what sensor type should i use if i know the input voltage, etc) they will just say they can't support you if you are not on their application list, but thanks for buying the product.. have a good day
I am thinking that the Emanage (about the same price range) would have been better, since last time I called Greddy (not even electronics related) about getting a part special order from Trust Japan, they were wiilling to help me work out my problem on the phone, on their dime (they called me back long distance)..
-joe
Offline
Old May 27, 2005, 08:14 AM   #6
403RA's Avatar
Drives: 88 turbo mirage - 04 black Ralli//Art
K, I've never done anything like this but I am really interested in doing it and an gonna take a stab at helpin out, so bare with me, LOL.
You may already know this ....
FYI the MAS sensors on our cars incorporate an Air temp sensor. The black wire (#4) coming off the sensor is the ground, the one beside it white-red (#3), is the MAS wire. The red wire (#2) is power. The yellow-blue wire (#1) is for the Air temp sensor. Wires #1, #3, and #4 goto the ECU. Wire #2 goes to the underhood fuse box to a relay.
Have you thought about hooking the s-afc II to the MAP sensor instead of MAS?
__________________
my blk RA 1, 2, 3, 4
Offline
Old May 27, 2005, 08:18 AM   #7
sillypuddy's Avatar
check engine light comes on when you hook it up to the MAP sensor
-joe
Offline
Old May 30, 2005, 08:50 PM   #8
sillypuddy's Avatar
can somebody who has it working help me out?
every sensor is working (RPM, throttle, etc) except for the airflow sensor part
I am using pin 63 (mass airflow sensor output) and pin 34 (or 33) for the ground.. these two pins i am unsure of..
when i check the voltage from pin 63, it's outputtting 8v at idle.. but the service manual says it should be 0 - 5v max.. so i am not sure why it's outputting 8v ..
anybody help?
-joe
Offline
Old May 31, 2005, 09:11 AM   #9
sillypuddy's Avatar
ok.. here's the deal
i am sick and tired of not getting the correct hookup and setup info for the safc ii
if you know how to get it going (and no, you can't use my car as the "experiment" vehicle..) and I confirm that your instructions are correct, I will give the following parts as a reward (or you can opt for $100 cash)
90% new K&N filter
100% new 2 gauge pod from autometer
95% new volt meter from stewart warner
pickup in toronto area
-joe
Offline
Old May 31, 2005, 12:31 PM   #10
Personal Sales Rating: (0)
punisherm's Avatar
Drives: 03 spec-v
Did you tap the map or the maf signal?.... We had to run ours of the map sensor. Couldn't get it to run off hotwire, it runs off the map sensor, 12-12 if I remember right.
__________________
03 Silver Spec
Hotshot header| Nismo CAI| SS| Suspension| FSB| RSB| LTB| Vibrant cat-back| JWT cams| JWT bsr| SafcII| Wilwoods| SS lines| Hawk HPS+| Megan dp
Offline
Old May 31, 2005, 12:50 PM   #11
punisherm's Avatar
Drives: 03 spec-v
Follow the diagram in M7-a except for the airflow pin. Use pin #101 for your airflow. Set your safc to read pressure and set it 12-12 for your sensor. It should run then. I haven't had a chance to take it to the dyno. It won't read off the maf signal because its reversed so it won't matter what you set your sensors to, the safc can't read that signal. The car will run off the map signal, but I don't know if you'll be able to make corretions or not. I don't know how the lancer is setup cause it acts like it has a maf and a map. If it makes corrections with just the map signal then you're golden. Like I said haven't been able to hit the dyno to make sure the setup is 100% right.
__________________
03 Silver Spec
Offline
Old May 31, 2005, 12:57 PM   #12
punisherm's Avatar
Drives: 03 spec-v
sorry its a pr-5 for sensor type not 12.
__________________
03 Silver Spec
Offline
Old Jun 1, 2005, 08:59 PM   #13
sillypuddy's Avatar
i figure out why we can't use the maf signal.. it's an easy fix and i am working on it
hotwire is much more accurate than the map signal.. which i prefer not to use right now
-joe
Offline
Old Jun 1, 2005, 09:31 PM   #14
reimundo's Avatar
Drives: TWIN TURBO SUPRA BPU
can someone post the instrution that came with the safc on here.
Offline
Old Jun 1, 2005, 10:22 PM   #15
punisherm's Avatar
Drives: 03 spec-v
-joe
Yep I know my bro is building one too..
__________________
03 Silver Spec
Offline
Tags
4g94, carrier, code, engine, lancer, oz, p0108, pigiback, position, retard, safc2, set, throttle, timing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
