Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Engine/Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 1, 2005, 10:50 PM   #16
Personal Sales Rating: (1)
evolsk8r's Avatar
Drives: '05 BMW M3 & '61 VW single cab, '63 rhd ragtop VW bug(sold), '06 Apex Silver IX MR- sold, '03 Apex Silver VIII- sold
Oops. Wrong car.
Offline
Old Jun 1, 2005, 10:52 PM   #17
Personal Sales Rating: (26)
Boeturbolancer's Avatar
Drives: Vulcan Mean Streak, Jeep Wrangler Unlimited X, YZ426F, F-250 Banks Diesel!
safc in ralliart
Although the sensor might appear to be a hotwire it is still a karmen vortex signal... you have to set the afc for the karmen sensor adjustment. You then need to intercept the MAF sensor wire. Basically you cut the wire and connect the SAFC stock signal input wire to the side going out to the sensor and then connect the modified signal wire from the SAFC to the wire going into the ecu. I'm including a simple ecu picture that should assist a little. I'm sure though that knowing it's actually a Karmens sensor will solve most of your issues.
black/yellow wire should be the 12V positive
brown/green wire should be the tach signal
black wire should be ground
white/red wire should be the MAF signal
You can compare these with your connections...
Since you said you have the knock and tps figured out these should get you set for the others. Now after you do all this and it starts working just pm me with my payment!
Seriously though i've done a couple and this should be the info you're looking for.
Good luck,
Boe
__________________
SC vs. TC...well, you wouldn't put a donkey in the Kentucky Derby would you? Are you ready to Turbocharge!! Always in moderation... boost responsibly.
Offline
Old Jun 1, 2005, 11:56 PM   #18
reimundo's Avatar
Drives: TWIN TURBO SUPRA BPU
^^^^ thanks boe. i'm sure this will help out a lot of people.
Offline
Old Jun 2, 2005, 01:58 AM   #19
rhyzin's Avatar
Drives: '02 Mitsubishi Lancer OZ "Rally" Edition
Send a message via AIM to rhyzin
holy **** boe. that's some ralliart gold right thurr! send him some money kiddies!!!
__________________
Dyno'd Lancers List
[ S C L C . n e t ] <- Southern California Lancer Club
Looking for stock parts? Look here first --\))> www.car-part.com
Basic Engine FAQ
Offline
Old Jun 2, 2005, 11:56 AM   #20
Personal Sales Rating: (0)
Drives: Ralliart Thunder grey TURBO
I'm not here to blow anything, I tried karman connection through the MAF red/white and it didn't work. The car justs idles ruff and if it idles at all excesive fuel smoke blows from exaust.
__________________
Got Boost.? Member 300+whp Club & Stock Internals..!
Offline
Old Jun 2, 2005, 05:42 PM   #21
Drives: 2004 Ralliart
Send a message via AIM to Treilix
hey BOE...FYI.....that no worky
Offline
Old Jun 2, 2005, 06:41 PM   #22
rhyzin's Avatar
well, if someone who has the RRM piggy on their ralliart can find a model number on the unit, then we can get to the bottom of all this. dunno why no one has checked yet.
__________________
Dyno'd Lancers List
Basic Engine FAQ
Offline
Old Jun 2, 2005, 06:44 PM   #23
Personal Sales Rating: (2)
blk-majik's Avatar
Drives: 08 RR Evo X GSR
thats the info from the RRM piggyback (i know cause those instructions came /w the piggy when i bought it ). anyway, others who have gotten it to work said that it was a karmen sensor as well. keep chug'n!
Offline
Old Jun 2, 2005, 07:04 PM   #24
rhyzin's Avatar
so what is exactly the problem??? the only thing either unit does is add or subtract voltage. how can we have CANs and CANNOTs?
it makes some sense that the MAF would send back a karmann signal depite being a different sensor. def cuts engineering costs.
__________________
Dyno'd Lancers List
Basic Engine FAQ
Offline
Old Jun 2, 2005, 10:30 PM   #25
it's karmen trust me... you have to calibrate the SAFC though. You also need to pull off the true tach signal source. Some people mistakenly took off the crank sensor or even cam sensor. If you do use the cam sensor you need to set the cylinder setup differently to read proper rpm settings.
Also the tps sensor needs to be tapped correctly. Once you've gotten all those tapped properly and the SAFC is reading everything correctly you should zero it out and all should be ready to go. I've worked on two units with the ralliart. Had no issues at all.
Karmen reads in hertz... setting the afc in karmen settings allows it to correctly see the input and modify output in a hertz format. It works... trust me. You've just gotta land the right wires. Don't use the crank sensor wire! For some reason it doesn't agree with the SAFC on the ralliart.
Just keep chug'n like blk-majik said!
__________________
Offline
Old Jun 3, 2005, 07:05 AM   #26
sillypuddy's Avatar
Drives: 2004 RA Silver
boe.. i checked my wiring against yours (the diagram you attached) and it doesn't line up
i am using
33 ground
34 power supply
63 maf
87 tach
89 knock sensor
115 throttle position sensor
-joe
Offline
Old Jun 3, 2005, 09:11 AM   #27
punisherm's Avatar
Drives: 03 spec-v
It definitely looks like a karman sensor but we couldn't get it to run when it was set to karman. We tapped the MAP signal and set the Safc up for pressure and it runs great.
__________________
03 Silver Spec
Hotshot header| Nismo CAI| SS| Suspension| FSB| RSB| LTB| Vibrant cat-back| JWT cams| JWT bsr| SafcII| Wilwoods| SS lines| Hawk HPS+| Megan dp
Offline
Old Jun 3, 2005, 07:50 PM   #28
sillypuddy's Avatar
Quote:
are you guys using PR5 as the sensor setting?
-joe
Offline
Old Jun 3, 2005, 10:28 PM   #29
punisherm's Avatar
Drives: 03 spec-v
It'll run on either 5 or 12... we chose 12 cause all the other mivecs run a 12
__________________
03 Silver Spec
Offline
Old Jun 5, 2005, 12:01 AM   #30
rickyMivec's Avatar
Drives: super ralli//art
it works or not
__________________
Ricky Tuning
14.3.95mph, 170+whp
N/A
NOS 274whp 276.80 torque. times coming soon
Offline
Tags
4g94, carrier, code, engine, lancer, oz, p0108, pigiback, position, retard, safc2, set, throttle, timing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
