Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Aftermarket Forced Induction Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 2, 2009, 08:38 PM   #1
Personal Sales Rating: (0)
Drives: Turbo RA
engine shaking
Hi all hope you can help. Last week the car was running fine, then when it got really cold the battery died on me, so i gave it a jump and when the car started the engine was shaking, white to grey smoke coming from exhaust, and when i press the gas pedal the rpms would not move and when i let off the car would die. Also the car is running really rich, cause when it was started i could smell gas. please help this is giving me a headache. Thanks.
Offline
Old Nov 3, 2009, 06:16 AM   #2
Send a message via ICQ to hackish Send a message via MSN to hackish Send a message via Skype™ to hackish
Change the sparkplugs. Most likely you've got a few fouled because of a rich startup. This is one of the reasons why I gave up on the piggyback stupidity - bad cold starts.
-Michael
__________________
One reflash can do what 5 different piggybacks cannot.
Offline
Old Nov 3, 2009, 11:41 AM   #3
Drives: Turbo RA
i did that and it is still he same, i also thought i might of got some bad gas and i even tried using gas line antifreze and still the same.
Offline
Old Nov 3, 2009, 03:18 PM   #4
Drives: Lancer ralliart 06 TURBO
You can check the injectors because sometimes they get jammed
Offline
Old Nov 4, 2009, 05:48 AM   #5
When you pulled the sparkplugs did you notice one looked different than the rest? That would indicate that it's running on 3 cylinders. I'd start with that if you've already tried changing them. With the car running you can also try unplugging each of the coils and when the note of the engine doesn't change you know that's your dead cylinder.
-Michael
__________________
Offline
Tags
car, dies, engine, exhaust, shake, smoke
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
