Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Aftermarket Forced Induction Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 1, 2009, 05:00 PM   #1
Personal Sales Rating: (0)
Drives: Lancer ralliart 06 TURBO
The coolant temp. is rising
Hi guys I'm having this problem and I want to know if you guys can help me. I've a turboed ralli 2006 and I recently have installed a megasquirt ecu to control the fuel and timing.When the car is in idle, I look in the computer to check the coolant temperature and it goes more than 210 degrees and the top hose of the radiator starts to leak coolant. I've changed the head gasket and fix the engine head, put the fans directy to the battery , changed the thermostat and the problem still exists.Please if you guys know something tell me. thanks
Offline
Old Nov 1, 2009, 06:46 PM   #2
The car is running solid I'm right now at 11.5lbs 336whp but after the megasquirt setup I'm having that problem. I'm not sure if the spark timing can affect this.
Offline
Old Nov 2, 2009, 08:35 AM   #3
Send a message via ICQ to hackish Send a message via MSN to hackish Send a message via Skype™ to hackish
Yes, timing can affect this but the cooling system in the car is more than adequate so I'd be looking at other places. At 11.5 psi it's possible that you're leaking some of that past the headgasket. Did you put in ARP head studs?
-Michael
__________________
One reflash can do what 5 different piggybacks cannot.
Offline
Old Nov 2, 2009, 09:19 AM   #4
Yes I have ARP studs
Offline
Old Nov 2, 2009, 02:33 PM   #5
Hi again; I have already solved the problem by flushing the coolant 10 minutes. The car is running solid solid right now and looking to get more boost.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
