Sep 22, 2009, 08:14 AM
Personal Sales Rating: ( 9)
2004 Mitsubishi Lancer
Drives: 2004 N/A RALLIART , 2003 6MT G35 coupe
RIPP BRat Box ECU add on
Hi guys this seems to be too good to be true isn't it. Turbo guys migth benefit from this especially the ones running the RRM kit or using piggybacks.
http://www.rippmods.com/RIPP_BRAT_Bo...mbrtb-0009.htm
__________________
RALLIART TURBO PARTS FOR SALE HERE
Offline
Sep 22, 2009, 08:29 AM
Personal Sales Rating: ( 2)
Drives: 2003 blue EVO
It's just a piggyback ECU. There is only so much you can do with these devices before the ECU adapts to the piggyback, then any benefits would be effectively lost.
__________________
autocross nut SFR SCCA #52 SM
Offline
Sep 22, 2009, 08:34 AM
Did you read the extended information this is not a PIGGYBACK you will need a piggyback along with this to run adjustments, what this does is basically trim the signals to some point so that the ECU does not realize it has been modified. Quite clever but expensive because you will still need a piggy but at least is another option.
__________________
Offline
Sep 22, 2009, 09:35 AM
Personal Sales Rating: ( 0)
Drives: Lancer ralliart 06 TURBO
I have read the specs and seems to work well. A lot of people can take advantage of that pretty well. Not for me because I'm in a proyect making it megasquirt right now.
Offline
Sep 22, 2009, 09:39 AM
I know you and Jorge, we talked yesterday about the throttle compatibility.
__________________
Offline
Sep 22, 2009, 09:40 AM
Personal Sales Rating: ( 5)
Drives: 2004 Mitsubishi Ralliart Turbo
damn... i think this is one of the best posts i came across in a while... awesome. this should make tuning with my piggyback a bit easier and more permanate. somebody buy this and try it out, let me know if it works with the split second piggyback or easy to tune with a turbo kit please.
awesome post migue
__________________
What do you mean "is that an EVO?" You were behind me the whole time, didn't you see that Ralli//Art emblem?
My Ride in the Registry...
My car on Youtube
http://www.youtube.com/view_play_lis...A57FD58D18C3E5
///RRM Turbo'd and proud. Trust me, you NEED this.
04-06 Lancer/Ralliart parts for sale!! (PM me)
-4g69 Heads
-Stock Hood (yellow)
-RRM turbo fuel/piggyback kit (both stage 1 and 2)
-Air conditioning system
-Maybe some spare motor parts (I have 3 motors)
-Much more!
Offline
Sep 22, 2009, 10:05 AM
hi, you mean the compatibility between the throttle and the mega?
Offline
Sep 22, 2009, 10:31 AM
Nope Jorge wants to eliminate the use of the throttle by wire and use just a standard wire throttle in order to use the megasquirt, I told him my understanding is that the Galant 200-2003 throttle is a cable one and works as a direct fit.
__________________
Offline
Sep 22, 2009, 11:07 AM
ohh ok thats good to know thanks but I've read about those computers and you can control the fuel and the timing only and leave the stock ecu managing the other components of the engine. You have to make too a custom crank trigger sensor.
Offline
Sep 23, 2009, 01:58 PM
Drives: 2006 W26 Mitsu Eclipse
I would seriously advise against this. Stay away from RIPP and as far as this product is concerned its just a really expensive E-bay resistor. Thats why if you talk to them they wont tell you exactly what it does or how it works. On C4G we had a member pull it apart and pretty much reverse engineer it to find out how it works. This is just my Opinon though take it or leave for what it is.
Offline
Sep 23, 2009, 02:00 PM
Quote:
Thats a lot of work changing TB's and the Gas pedal and everything, but good luck hopefully it works out for you guys
Offline
Sep 23, 2009, 04:26 PM
Quote:
I don't think the pedal has to be changed, luckily the ralliart has a hydraulic cable that gets as far as the passenger side headlight , there you will find a TPS and the system that acts as a throttle then the signals get sent from the ECU to the Throttle by Wire at the intake manifold, so if you go standalone just remove the throttle at the manifold put a mechanical one and use the oem cable or fabricate a new one. To be honest if you are going standalone this shouldn't be a problem.
__________________
Offline
Sep 23, 2009, 06:02 PM
Don't know about the ralliart but in the 4g the pedal is electronical as well. Has a Wire Harness that plugs in underneath the dash that runs to the ecu
Offline
Sep 23, 2009, 07:51 PM
I am telling you how the ralliart is because after all, this is a RALLIART thread. The ralliart does NOT have an electronic pedal, it actually has a cable that goes all the way to something similar to a throttle , personally I think putting this device behind the headlight is lame first because most of the accidents tend to be frontal collisions and in the event of that if you do crash that side you wont even be able to accelerate the car and second because it is actually a waste of space and cable they could put that somewhere else and leave that part alone for us to pass thru the intercooler piping   , anyway I have attached two images explaining the layout the first one is a picture of my engine bay , follow the red line between the radiator and the engine and it will guide you to the throttle TPS housing. The second one is a close up of that assembly. Again our engines may have the same engine code but there are trivial differences between them for instance the intake manifold on your engine is different and so is the cylinder head. Anyway the idea is to remove that cable and housing and the stock electronic throttle, install a 2000-2003 throttle and put the end of this cable to the galant throttle, calibrate the galant TPS to work with the megasquirt and there you go.... away the Throttle by wire system.
__________________
Offline
Sep 23, 2009, 11:15 PM
Yeah I knew there where difference's I wasn't trying to say you werent correct in your statement just trying to explain why I originally thought maybe you would have too.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
