Jun 30, 2009, 06:02 PM
Personal Sales Rating: ( 0)
Drives: 2004 mitsubishi lancer ralliart
Stupid or not?
im planning on boosting my ra. im going to fabricate my own header and once i do im planning on leaving the turbo hooked up.can you run a turbo without the cold side hooked up temporarily or will it kill lots of power ?
thanks
zach
Offline
Jun 30, 2009, 06:23 PM
does anyone know?????
Offline
Jun 30, 2009, 08:32 PM
dang,
this must be a good question!!
Offline
Jul 1, 2009, 12:12 AM
ok so am i a complete idiot or does no one know the answer to this question
20 people have read this thread and usually by now i at least would have been called a
dumb A$$ or something
little help please?
Offline
Jul 1, 2009, 07:29 AM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
You'll lose power but the car will function. You won't want to do it without having the oil lines hooked up to the turbo, either.
Offline
Jul 1, 2009, 01:13 PM
Personal Sales Rating: ( 1)
Drives: .
I'm gonna go with stupid to answer your question.
__________________
Offline
Jul 1, 2009, 01:24 PM
yea i know the oil lines have to be hooked up
(and why stupid? if you know.... more info on why its stupid.)
Offline
Jul 1, 2009, 01:30 PM
Drives: 04ralliart
im gonna say that there are only stupid people, no stupid questions. I dont know the answer but if im not sure of something i usually dont do it, cuz who knows what else you might f**k up?
Offline
Jul 1, 2009, 01:56 PM
Drives: 04 Ralliart N/A, 68 Camaro
why wouldn't you wanna use the aftercooler (intercooler)? Lower intake temps. Better performance. There are kits out there that do not use an intercooler and even some factory cars that never came with intercoolers. I just see negative affects when not using an intercooler. That is my experience. All up to you though.
__________________
Fastest Ralliart NA (Under Construction) SSP crankshaft, SSP camshaft, SSP cylinder head, SSP 14:1 pistons, SSP Flywheel, SSP twin disc clutch, soon more custom products for the drag car.
Fastest NA RA E.T. 12.7 @ 110 (Ran w/RRM products)
First RA in the 12's
Offline
Jul 1, 2009, 02:22 PM
Quote:
I think you're missing what he's asking. He's asking if he can build a turbo manifold (I'm assuming out of his stock one, otherwise this is a really stupid question) install the turbo onto the exhaust, but don't actually hook it up to the car's intake. Basically, the turbo won't be doing anything but spinning and throwing air around the engine bay.
Offline
Jul 1, 2009, 02:32 PM
Personal Sales Rating: ( 6)
Drives: 03 Evo 8 rally red
i'd say wait til you have everything ready and then hook everything up together at the same time,
the car will function but I'm guessin you'll get lag just like any normal turbo car depending on the size of the turbo
and if you do have the oil/coolant lines hooked up the turbo should operate normally except for the fact that its just pushin air around the engine bay instead of into the intake manifold
__________________
ignorance is bliss
Offline
Jul 1, 2009, 02:44 PM
Personal Sales Rating: ( 3)
Drives: 06 Ra MT
yeah, i dont think you can engineer a turbo manifold.. unless you work for GM.. then I completely understand where you're coming from.
__________________
Next: Internals
WTB: Zaklee engine damper
Offline
Jul 1, 2009, 03:48 PM
Drives: mitsubishi lancer ralliart cool silver 04
I am sure if you can make a manifold for your turbo you can make a block of plate to go over where the turbo sits till you get everything else ready for install. I personally would not hook the turbo up just to the exhaust side because you dont want to suck somthing in the turbo and not have a filter on it. If your going to put piping and a filter then you might as well hook everything else up also. Just a little thought, why would you have your turbo spinning and collecting all that heat when its not doing anything for your motor at all ?? I would refer back to my first statement, block of plate if anything.
Offline
Jul 1, 2009, 03:50 PM
Drives: 2004 Lancer Ralliart
Find someone selling a manifold to make a turbo manifold and then you won't have to mess with it. A stock header sells for cheap and I'm sure someone on here with an aftermarket setup would send you their old stock one.
Offline
Jul 1, 2009, 05:45 PM
Drives: 2006 Lancer Ralliart
Shure you can do it!!!! I did it  and had it running like that for about 2 weeks; the reason was that I had some problems with my maf adaptor (didn't want to cut my air box) ........ any way it works fine...but you will lose power, and a lot 'cause the turbo is a big restriction for the exhaust (my wild guess - never measured it- is arround 20hp)
Insisting on what otter said remember to hook your oil lines or you will kill your turbo.
Also remeber you'll need two air filters one for the engine and one for the turbo (it will suck air), what I did is that I installed a aftermarket cone filter directly to the turbo and let the engine with the original air box.
For the manifold, this may help: http://autospeed.com/cms/A_2604/article.html
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
