May 25, 2009, 11:12 AM
Personal Sales Rating: ( 0)
Drives: RalliART
Will UDP work with the turbo?
I have decided to go turbo so I'm getting rid of my bolt on, so I was wondering if the UDP is a good fit for the RA turbo? Should I sell it or keep it?
Offline
May 25, 2009, 05:11 PM
Personal Sales Rating: ( 5)
Drives: 2004 Mitsubishi Ralliart Turbo
keep it.
__________________
What do you mean "is that an EVO?" You were behind me the whole time, didn't you see that Ralli//Art emblem?
My Ride in the Registry...
My car on Youtube
http://www.youtube.com/view_play_lis...A57FD58D18C3E5
///RRM Turbo'd and proud. Trust me, you NEED this.
04-06 Lancer/Ralliart parts for sale!! (PM me)
-4g69 Heads
-Stock Hood (yellow)
-RRM turbo fuel/piggyback kit (both stage 1 and 2)
-Air conditioning system
-Maybe some spare motor parts (I have 3 motors)
-Much more!
Online
May 25, 2009, 09:05 PM
Drives: RalliART
Ok. Thanks man.
Offline
May 26, 2009, 07:47 AM
Bad idea. When you go with boost you end up with a lot more crankshaft deflection (obviously since you're making more power). You need the harmonic damping of a stock or properly damped pulley.
Offline
May 26, 2009, 08:50 AM
__________________
My car on Youtube
-4g69 Heads
-Much more!
Reason: lol nevermind
Online
May 26, 2009, 02:40 PM
Drives: 2004 Ralliart Demon
what?.....I guess it helps but usually when you increase the power or do things that do a negative effect on the engine you get parts that do a positive effect creating a solution or a balance.
__________________
Current Mods: RRM SRI, RRM P&P intake manifold, RRM camshaft, RRM piggyback, RRM underdrive pulley, RRM motormounts, STM balance shaft eliminator kit, Evo big bore fuel rail, Megan fuel regulator, Walbaro fuel pump, OBX headers with zeitronix ZT-2, 2.5" midpipe, CXRacing Evo radiator, Tein suspension, RRM slotted rotors, Rota Racing Grid 18x8.5 with Yokohama S drive 215/40.
In 1 month: GT35R Turbo with pistons and rods.
Offline
May 26, 2009, 11:55 PM
Drives: RalliART
Hackish, so you suggest putting back the stock pulley? What would be the neg effect of keeping it?
Does someone with the UDP and a turbo kit please let us know his opinion?
More info guys please.
Offline
May 27, 2009, 11:54 AM
i had the pully on with the turbo kit for 2-3 years with no problem at all.
__________________
My car on Youtube
-4g69 Heads
-Much more!
Online
May 27, 2009, 12:01 PM
Personal Sales Rating: ( 3)
Drives: '05 Turbo RA
I've had turbo + pulley for six months, also no problem.
Offline
May 27, 2009, 03:03 PM
Yes, I suggest putting the stock pulley back on. 9 times in 10 you won't have a problem unless you're pushing 300+hp. It's that other 1 in 10 times where you have the problem and have to replace the engine.
-Michael
Offline
May 27, 2009, 08:46 PM
Drives: 06 Ra MT
what's your reasoning?
__________________
Next: Internals
WTB: Zaklee engine damper
Offline
May 27, 2009, 09:16 PM
Personal Sales Rating: ( 1)
Drives: 04 Ralliart N/A, 68 Camaro
well just run the pulley. I don't have any issues with my high compression engine which is over 300+hp. I haven't seen any issues running the RA with over 300+hp with an UDP. But also i have done the cranks for these RAs also. #1 crank pin and rod journal are out of balanced. There is a possibility of damaging the engine by running the UDP but i have yet to see it with the absence of the vibration dampener. Remember this, whenever you modify anything there is a chance of failure which is why i am sure hackish brought that up.
__________________
Fastest Ralliart NA (Under Construction) SSP crankshaft, SSP camshaft, SSP cylinder head, SSP 14:1 pistons, SSP Flywheel, SSP twin disc clutch, soon more custom products for the drag car.
Fastest NA RA E.T. 12.7 @ 110 (Ran w/RRM products)
First RA in the 12's
Offline
May 28, 2009, 12:59 PM
Quote:
Crank deflection is proportional to the amount of force applied by each piston. This means the more power you make the more it will deflect the crank as each cylinder fires. This deflection is the beginning of crank harmonics. Damping these will stop the crank from "ringing". If you have the time there are many SAE articles and other engineering pieces written on the math to calculate these things.
-Michael
Offline
May 29, 2009, 12:14 PM
Drives: 06 Ra MT
okay.. and having a heavier pulley will help this... how?
__________________
Next: Internals
Offline
May 29, 2009, 12:27 PM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
It's not an issue of weight, it's an issue of vibration absorption. The stock pulley is actually a 3 piece pulley. A steel center, wrapped in dense rubber, then the outer steel part that the belt rides on. That dense rubber absorbs vibration in the crankshaft.
Online
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
