Mar 20, 2009, 11:20 AM
Personal Sales Rating: ( 0)
Video of reflashed car.
I'm a tuner and programmer, not a videographer.
http://www.youtube.com/watch?v=5KYHkOB04tI
Just thought it would be nice to put a video to it. I'm going to build a launch control feature similar to the honda stuff. As you can see the from the photos in the video the piggyback has been removed and it's only running on the factory ECU.
-Michael
Offline
Mar 20, 2009, 07:00 PM
Personal Sales Rating: ( 1)
2006 Mitsubishi Lancer
Drives: 06 Ralliart AT
hope a dyno video comes next?? =)
Offline
Mar 21, 2009, 07:21 AM
Still got a little more work to do on the tune and the closed loop settings. I want to deliver the car with a proper over-boost cutoff so something stupid like a burned wastegate hose doesn't spell the end of your engine.
Offline
Mar 21, 2009, 11:40 PM
2004 Mitsubishi Lancer
Drives: 04 RA
Quote:
-Michael
apparently not an english teacher either.
good work man, cant wait to see the finished product!
__________________
[x] RRM piggyback
[x] RRM UDP
[x] RRM SRI
[x] RRM SS clutch line
[x] RRM rear strut bar
[x] 2.5 Otto Exhaust
[ ] RRM stage 2 Camshaft
[ ] RRM stage 1 clutch
http://www.cardomain.com/ride/2941543
Offline
Mar 22, 2009, 11:44 AM
Quote:
I do not see the error.
Offline
Mar 23, 2009, 12:55 PM
Drives: 04 RA
/facepalm
note to self, do not log onto evom after having a few
__________________
[x] RRM piggyback
[x] RRM UDP
[x] RRM SRI
Offline
Mar 23, 2009, 02:12 PM
Drives: 2005 Lancer Ralliart
Good stuff..next a video on the road?
__________________
2005 Ralliart
RRM Cold Air Intake
Offline
Mar 23, 2009, 05:05 PM
/facepalm
After drinking and driving only 2 are worse...
1. Drinking and Typing
2. Drinking and dialing.....
Offline
Mar 23, 2009, 10:49 PM
Still trying to explain those 1-900 charges on your phone bill?
Offline
Mar 25, 2009, 04:24 PM
Drives: .
Why does it only rev to 4500 rpm? Isn't that "limp mode"? If so, why would you post a video of that?
__________________
Offline
Mar 25, 2009, 05:53 PM
Drives: 04 RA
IIRC he said in a previous he did a proof on concept by changing the rev limter on the ecu.
__________________
[x] RRM piggyback
[x] RRM UDP
[x] RRM SRI
Offline
Mar 25, 2009, 05:58 PM
Drives: 2004 White Ralliart 5speed
That's odd. In his first post it seems as if he's GOING to build a rev limiter for it.. as if it's not done yet.
I know my car limits my revs at 4500rpm sometimes. I'm guessing it does that when it's cold? I've had it in neutral and revved it up to red line before. I've never tested this theory out though..
__________________
Pearl White 2004 RALLI////ART Lancer . RRM CAI . RRM Header . RRM Downpipe . RRM Highflow CAT . Custom Catback Exhaust . RRM UDP . Slotted Rotors in the front . Cross Drilled Rotors in the back
Offline
Mar 25, 2009, 06:09 PM
You guys are missing the point......he changed the rev limiter to prove that he has cracked the ecu and can make changes and by changing the rev limiter it is an easy demonstration to show you guys......
Setting the rev limiter at 4500rpm is an easy way to show that he can do it and if he can change it to 4500rpm he can set it to what ever he wants to.....
Offline
Mar 26, 2009, 06:43 AM
Yes, the rev limiter was changed purposely to show that it was done. The video also shows that it's running 550cc injectors at pretty close to stoich and it's not even in closed loop yet - still in warmup. No piggyback, no maf adjuster, just a reflash.
Offline
Mar 26, 2009, 06:35 PM
Drives: .
Thanks for clarifying.....I was just going off the information in this thread (OP didn't mention what was actually happening....just that a Ralliart ECU had been reflased). I didn't search any of your other threads.
Good luck to you.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
