Sep 8, 2008, 09:17 PM
Personal Sales Rating: ( 0)
Drives: 06 Lancer Ralliart
Car bogging on wot
k my turbo spools up nice but when i go wot around 3000rpm and 4500 rpm it will bog and backfire. but i can go to redline if i accelerate slowwwwwwly. just when i give gas it bogs and will backfire if i try to make it. check all the rubber boots for cuts and found none. i have had it boost nicely but only twice and try again hr later and it bogs again. why what is the problem. im getting nothing but bad luck lol someone brighten my day with a solution.
Offline
Sep 10, 2008, 06:56 PM
k so now my tank is almost empty and my turbo was spooling ful with no problems and felt good! so why when my tank is full is it bogging and on empty it boosts nice and hard?? im using 91. is it picky on where i get my fuel from? it was from a mac's gas station? anyone have any info or suggestions?
Offline
Sep 10, 2008, 10:44 PM
Drives: 2006 ralliart
so you filled the tank back up and it started bogging again?? if thats the case it sounds like a tuning problem. possibly like your to rich??? this may not be relavent, but i had a two stroke engine that ran more lean at the end of the tank, it could be that yours is doing the same?? just a thought...
Offline
Sep 11, 2008, 12:24 AM
well i left the house again on empty tank and same thing back to bogging so it bogs full tank or empty tank and boosts only if im lucky once a week
Offline
Sep 11, 2008, 12:25 AM
2004 Mitsubishi Lancer
Drives: 04 RA
check fuel lines for blockages?
__________________
[x] RRM piggyback
[x] RRM UDP
[x] RRM SRI
[x] RRM SS clutch line
[x] RRM rear strut bar
[x] 2.5 Otto Exhaust
[ ] RRM stage 2 Camshaft
[ ] RRM stage 1 clutch
http://www.cardomain.com/ride/2941543
Offline
Sep 11, 2008, 01:25 AM
Drives: 2006 RA Lancer
^check lines, check fuel filter,
if u can try fill above 91ron ...
__________________
Quote:
Originally Posted by Lancer7
Fake titties are like driving an ES with an Evo body kit. They look good till you put your junk in the trunk and find out they don't go anywhere.
Quote:
Originally Posted by CleverUserName
you'll pull dudes all day in an evo, whether you want to or not.
Offline
Sep 12, 2008, 05:51 AM
Personal Sales Rating: ( 1)
Drives: Ralli
It is probably the stock ecu going crazy when you don't floor it and it is reading a lot of air going into the engine...
floor it and see if it keeps "bogging"
if is the stock ecu it won't back fire at WOT
Offline
Sep 12, 2008, 05:52 AM
Drives: Ralli
what ecu are you using if any?
Offline
Sep 12, 2008, 05:59 AM
2006 Mitsubishi Lancer
Drives: 2006 Mitsubishi Lancer Ralliart
gravity fed fuel system?
Online
Sep 12, 2008, 09:21 AM
wot throttle it bogs and if i go easy its ok. im using the rrm's piggy back the split second. but im gonna tune it cause i think thats the prob
Offline
Sep 17, 2008, 11:45 AM
Drives: 2004 Lancer RalliaArt
the fuel filter is non servicable to my understanding but are you on a return system or just rrm kit?
Offline
Sep 18, 2008, 07:25 AM
Personal Sales Rating: ( 13)
Drives: 2003 VIII, 1987 E30
Check spark plugs. They might be bad. My evo had the same problem you're describing when the plugs went bad. GL.
__________________
Philadelphia Region SCCA - #107BSP
PeteyTurbo Tuned|krazyhousecustoms.com
Offline
Oct 19, 2008, 10:03 PM
Personal Sales Rating: ( 6)
Drives: 90 eclipse gsx 2003 silver evo
check the fuel return line or maybe even the vent hose for the fuel fill.....do u have a fuel pressure regulator or gauge to know what fuel pressure u are running?
Offline
Oct 19, 2008, 10:10 PM
Offline
Oct 21, 2008, 12:45 AM
Personal Sales Rating: ( 19)
Drives: 06 Apex Silver Evo IX
I'm having the same problem, slow boost to about 10PSI then spikes to 22, stutters, and backfires/small explosion feeling
Could this be cause of spark plugs?
__________________
XS-Engineering DP, HFC, Megan CB, Cone Filter, Walbro, Hallman MBC @ 21psi, 4WS tuned
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
