Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Aftermarket Forced Induction Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 10, 2008, 11:05 PM   #1
Personal Sales Rating: (1)
Drives: 06 lancer RA
Ideal internals for FI?
so this is my goal http://www.youtube.com/watch?v=ImBgojbvd-Y
and now begins the question process
how do you know what compression to use with a FI application?
speciffically i'm planning on going with ripps stage 2 s/c kit, but i would like to build the internals as well.. so i was thinking of forged rods and pistons with lower compression pistons and a FI specific camshaft...
from what limited FI knowledge i know its benificial to run a lower compression piston but how would you know what to go with?
what else is there i could replace when building the engine since i'd have it all apart anyhow
__________________
stuff for sale http://forums.evolutionm.net/showthr...87#post5118187
Offline
Old Jul 10, 2008, 11:27 PM   #2
Personal Sales Rating: (10)
Drives: 91 talon awd gt42r, 91 eclipse gst stock, 1989 Turbo Mirage 4g63 swap, 95 talon awd gt35r, 03 TB VIII, OB Evo X.
Send a message via AIM to tsi20gawd Send a message via MSN to tsi20gawd
8.0-9.0 is the "standard" Compression ratio for forced induction applications. Remember with a lower compression ratio you can run slightly more timing and more boost, than a high compression varient.
Bryan
Online
Old Jul 10, 2008, 11:45 PM   #3
yea that pretty much the only thing i know about FI mods... is there a way to know if 8 is too low or 9 is too high for your application?
oh i'm looking to have this all up and running for next spring so gives me ample time to do my homework and get everything done properly the first time
as for components what else is there for strengthening the engine?
-head bolts
-pistons
-rods
feel free to add to this list
i'm also planning on having the head, intake manifold and throttle body P&P
and a a 2.5inch exhaust...so downpipe,midpipe,high flow cat and cat back system
i assume upgrading the injectors, fuel rail and fuel pump are all good thigns to do as well
__________________
Offline
Old Jul 11, 2008, 08:10 AM   #4
EvoM Super Moderator
2009 Toyota Tacoma
My Garage
otter's Avatar
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Send a message via AIM to otter
IMO, unless you're planning high boost levels, I don't see a reason to venture away from the stock 9.5:1 compression level. Besides your short list (head studs, not bolts), you'll need main studs and new rod bolts.
__________________
READ EVERYTHING IN THIS LINK BEFORE PM'ING ME ABOUT WHY YOU CAN'T POST IN THE CLASSIFIEDS!!!
Problem with a post or thread? Use the report post button, it's faster than PM'ing a single Mod.
Read and obey the rules to help keep this forum a great place!
My Ralliart
Michigan Evo/Lancer club
Offline
Old Jul 11, 2008, 03:09 PM   #5
Personal Sales Rating: (0)
RalliDew's Avatar
Drives: 2004 Lancer RalliaArt
Send a message via AIM to RalliDew
evo fuel rail works but i would not change that until you get all the s/c stuff squared away then start that adventure.
Offline
Old Jul 11, 2008, 03:37 PM   #6
the evo rail will work with RA engines.. hmm didn't know that
as for internals should i stick to OEM or get forged?
main studs? and rod bolts?
wheres the best source for the studs? head and main
would the bolts come with the forged rods or no?
__________________
Offline
Old Jul 11, 2008, 03:45 PM   #7
It really depends on your goals wich Im sure you have heard a thousand times so far. If you looking for a quick 50-60hp run 5psi on your stock internals but watch your plugs for detonation! Headstuds would be good insurace however without them you would more than likely blow the headgasket than melt a piston, choose your fuse.
Bryan
Online
Old Jul 11, 2008, 03:51 PM   #8
well the stage 2 kit is running 12psi but apparently it loses 3psi threw th FMIC so its really running at 15psi :S?
so i guess what i'll be running is 12psi either way its putting down 307 WHP
speaking of plugs i heard running a colder range plug is good for FI
if i was to change to a colder plug how would i go about picking which one?
__________________
Offline
Old Jul 11, 2008, 04:05 PM   #9
2009 Toyota Tacoma
My Garage
otter's Avatar
Here's the breakdown for NGK part numbers, it'll help you chooose a plug.
http://www.spark-plugs.co.uk/pages/technical/ngkjpg.htm
__________________
My Ralliart
Offline
Old Jul 11, 2008, 04:24 PM   #10
wow good link.. anyway how to know how much colder if at all i should go?
and what metal type should i go for.. pretty sure comes in copper,iridum and platinum... i can't rememeber fully been a long day
__________________
Offline
Old Jul 11, 2008, 04:29 PM   #11
heatrange 7 is common for ngk's in forced induction applications.
Bryan
Online
Old Jul 11, 2008, 04:33 PM   #12
thanks guys... what about plug type? just stick with the standard metal think its iridum...
__________________
Offline
Old Jul 11, 2008, 04:48 PM   #13
$MIVEC$'s Avatar
Drives: 06 Rio Red RA
stock rods are forged and imo proven durable
Offline
Old Jul 11, 2008, 04:51 PM   #14
stock rods are already forged? good to know... i thought i heard somewhere the rods where the weak poin tin the engine
so if the rods are forged already go with forged 9.5-1 pistons?
so makes the list;
-forged pistons
-rod bolts
-main studs
-head studs
-colder range plugs
since i'll be P&P the head is there better valves and springs to get or just use originals>?
__________________
Offline
Old Jul 11, 2008, 04:57 PM   #15
Standard copper el cheapo Ngks are usually the most common.
Bryan
Online
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
