May 31, 2008, 04:47 PM
Personal Sales Rating: ( 0)
Drives: 2006 Eclipse GS-T
Raising the idle rpm's
Is there a way to raise the rpm to about a 1000 on our engines? Cause my car would feel much better that way. I know the Eclipse is a bit different than a Ralliart, but the engines are the same and we have drive by wire throttle.
__________________
Garrett T3/T4 50 trim, Tial wastegate, Greddy BOV, NGK wideband, Lucas 550cc injectors, Aem Fic, custom manifold with ceramic coating + much more
Offline
May 31, 2008, 05:15 PM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
You could force it by tightening up the throttle cable, but it wouldn't be the right way. Our idle is controlled automatically by the ECU, so there's no mechanical way to adjust it.
Offline
May 31, 2008, 11:18 PM
2004 Mitsubishi Lancer
Drives: 04 RA
and our ecu still hasn't been cracked..... -_-
__________________
[x] RRM piggyback
[x] RRM UDP
[x] RRM SRI
[x] RRM SS clutch line
[x] RRM rear strut bar
[x] 2.5 Otto Exhaust
[ ] RRM stage 2 Camshaft
[ ] RRM stage 1 clutch
http://www.cardomain.com/ride/2941543
Offline
Jun 1, 2008, 10:14 AM
Well I need to figure something out, cause the car always worked better at a bit higher rpm's. Especially now that the summer is here. I can't even turn on the AC cause the car might die out. It might be these stupid spark plugs that are in, although the guys at the shop are saying it's not. I have these NGK 3672 plugs that someone recommended, but I do remember them being a bit shorter than stock.
__________________
Offline
Jun 1, 2008, 10:38 AM
Yeah, if your car is having issues holding idle, you definitely need to fix the problem instead of trying to hide it.
If you still have the stock plugs, throw them in really quick to see if that fixes the idle issue or not.
Offline
Jun 1, 2008, 06:36 PM
Personal Sales Rating: ( 8)
Drives: your mom crazy with my striking good looks
you are running 500cc+ injectors right? that might be stretching the ECU adjustments a bit  only thing I can think of off the top of my head.
you will definitely have to wait for the ECU to be cracked before you can adjust target idle. I agree with otter: you should not try to hide the issue, unless of course you find the ECU is having trouble compensating...
__________________
wtb 4g69 bottem end. pm me.
Offline
Jun 1, 2008, 08:57 PM
Personal Sales Rating: ( 1)
Drives: 04 Ralliart N/A, 68 Camaro
If the ECU isn't compensating enough then the car is out of fuel control. No need to try and adjust idle. Means you have a vacuum leak somewhere or running too rich. You need to find out what your O2 sensors are reading and your STFT/LTFT. That will tell you everything.
__________________
Fastest Ralliart NA (Under Construction) SSP crankshaft, SSP camshaft, SSP cylinder head, SSP 14:1 pistons, SSP Flywheel, SSP twin disc clutch, soon more custom products for the drag car.
Fastest NA RA E.T. 12.7 @ 110 (Ran w/RRM products)
First RA in the 12's
Offline
Jun 1, 2008, 08:58 PM
You can adjust your fuel delivery if that is the culprit to have your ECU run as was designed.
__________________
Offline
Jun 2, 2008, 04:09 PM
It does feel like there's a leak somewhere, but my afr's are perfect.Someone on this site recommended me the NGK 3672 plugs, which are a bit shorter. You think that might be the problem?
__________________
Offline
Jun 2, 2008, 05:49 PM
anything is a posibility, how much shorter? do they stick out of the head at all? it's a particularly long shaft
I thought you had already gone back to the stock fuel setup and still had the issues, were the plugs not included in that swap?
__________________
Offline
Jun 2, 2008, 05:55 PM
Drives: 2006 GG Mitsubishi Lancer Evolution MR. Any Car on my Dealership.
Put some Champions in there.
__________________
AMS FMIC
ACT XTSS
AMS SS CLUTCH LINE
MEGAN O2
GREDDY Ti-C CATBACK
DC Sports DOWNPIPE
HKS R.S.I.
Hallman MBC @23 PSI
FORGE B.O.V.
WALBRO 255
Cosworth M2's
SuperTech Dual Springs/Ti-Retainers
ARP Headstuds
ETS 2.5" Upper/Lower I.C. Pipes
Kuniiizzzeee Dial-IN
11.9 @ 116mph (6-speed MR)
Next Mods: FP Black on VP Import
Sponsored by my own dealership! http://www.mainstreetmotors.org
Offline
Jun 2, 2008, 08:48 PM
I don't know anymore. There seems to be different problems at different times. I'm going nuts over here. It's been 2 months since the car worked properly.
__________________
Offline
Jun 2, 2008, 09:03 PM
Done a vac test lately?
Offline
Jun 9, 2008, 04:53 PM
Drives: Ralliart Thunder grey TURBO
I fixed mine drilling an adjusting screw on the TBW actuator and adjusting it ti'll the idle was ok.
__________________
Got Boost.? Member 300+whp Club & Stock Internals..!
Offline
Jun 10, 2008, 05:37 AM
Where exactly did you drill, and do you have a picture of it?
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
