Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Aftermarket Forced Induction Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 5, 2008, 11:48 AM   #1
Personal Sales Rating: (0)
Drives: 2006 Eclipse GS-T
MAF Pipe Diameter
I'm still having issues with the fueling. The car wasn't running perfect even with the stock injectors and ECU. Everything is hooked back up and after a few days now, it started acting up again. The mechanic says it's because of the pipe diameter. We used the 2.5" pipe when we made the kit. I have to find out the exact size and convert it to suck thru set up also. Would that be the issue, cause the car goes down to mid 10's when I stop at the lights and then climbs up to 14's? Sometimes it will die out.
__________________
Garrett T3/T4 50 trim, Tial wastegate, Greddy BOV, NGK wideband, Lucas 550cc injectors, Aem Fic, custom manifold with ceramic coating + much more
Offline
Old May 5, 2008, 12:03 PM   #2
EvoM Super Moderator
Personal Sales Rating: (10)
2009 Toyota Tacoma
My Garage
otter's Avatar
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Send a message via AIM to otter
Dying front O2 sensor? The stock MAF pipe is 2.5".
Do you have a tactrix cable so you can log and see if anything seems off?
__________________
READ EVERYTHING IN THIS LINK BEFORE PM'ING ME ABOUT WHY YOU CAN'T POST IN THE CLASSIFIEDS!!!
Problem with a post or thread? Use the report post button, it's faster than PM'ing a single Mod.
Read and obey the rules to help keep this forum a great place!
My Ralliart
Michigan Evo/Lancer club
Offline
Old May 5, 2008, 12:16 PM   #3
I changed to brand new O2 sensors. The only codes are bank 2 too rich and misfire. It's not misfiring like before. I know the afr's are messed up, cause the tune was according to a dying maf. Now the new maf is in and the tune is all over the place. Which is ok, but I ran rich before and wasn't making the car die out. If the pipe is 2.5" then I'm not spending anymore money to fix something that won't work anyway. It could be different on the Eclipse though.
__________________
Offline
Old May 5, 2008, 01:10 PM   #4
$MIVEC$'s Avatar
Drives: 06 Rio Red RA
Where is the MAF located on your piping?
Offline
Old May 5, 2008, 01:13 PM   #5
Stock position, about 6-8 inches from the throttle body. It's just sitting upside down so it looks cleaner.
__________________
Offline
Old May 5, 2008, 01:52 PM   #6
Personal Sales Rating: (8)
Drives: your mom crazy with my striking good looks
how far from the BOV is it? could it be sensing air bouncing off the throttle plate or maybe air going through it backwards altogether? this was an issue I was told to be wary of when pressurizing the MAF, but it was more towards directly after you come off the throttle.
+1 on the tactrix cable, from my last phone call (she still hasn't called me back ) CAN bus support should be out or was immediately forthcoming. I didn't ask so I for sure; it wasn't the topic of discussion
__________________
wtb 4g69 bottem end. pm me.
Offline
Old May 5, 2008, 02:12 PM   #7
2009 Toyota Tacoma
My Garage
otter's Avatar
Quote:
Do you think the issue could be because you're pressurizing the MAF when you're not supposed to?
__________________
My Ralliart
Offline
Old May 5, 2008, 02:40 PM   #8
Dan might have a point there. Maf is only about 2-3 inches from the bov. The reason why I had to buy a new maf was cause of a bov that was open at idle. I'm guessing it does the same when you let off the gas. But anyway we will be converting it to a suck thru set up. I'm just waiting on a Greddy BOV to arrive. So Ralliart pipe is 2.5"? And how much would it affect if it was a bit smaller?
__________________
Offline
Old May 5, 2008, 07:27 PM   #9
I was gonna suggest recirculation as a way to slow the transition, but thought it might hamper your efforts to find the root problem if that's not the cause if it takes three days to show up you are a long way away by trial and error
mounting it upside down would make it more susceptible to moisture, just like an o2 sensor. I'm not sure how much condensation would affect it though.
the MAF has been pressurized before, otter. thunder-rush did it for sure, and I am sure there are others.
edit: also, try putting the BOV in different places to see if there is a change. more grasping at straws though, I'd look into more data logging options before too long doesn't always help, but it can't hurt
__________________
Offline
Old May 5, 2008, 07:42 PM   #10
It only took couple of days for the fuel trims to settle. Now, any change should be visible right away. I'm kind of unsure of what to do next, cause they told me that even after putting the new maf in and running the stock injectors and ecu the AFR's were still all over the place. There's something seriously wrong somewhere and they're saying it's the maf pipe diameter, and they want to keep going. Of course this is costing me a lot of money, and I don't wanna keep spending if the car is ****ed. I need to get the Evoscan.
__________________
Offline
Old May 5, 2008, 10:46 PM   #11
$MIVEC$'s Avatar
If it helps qlitv's solved the rough idle and being to rich by pressurizing the MAF. After testing a few things the maf pressurization was the last resort and it worked
Offline
Old May 6, 2008, 06:16 AM   #12
his is already pressurized.
well, put the stock airbox back on and test it out. I took otters word for it and didn't measure, but 2.5 what I remember as well. oversized MAF pipe would, generally speaking, only lean it out unless the turbulence was real bad
__________________
Offline
Old May 6, 2008, 07:44 AM   #13
I guess it's not really pressurized at idle, or when I get off the throttle. That's when the bov stays open. Now that the warm weather is here, it seems about .25" open. It could be the reason for my troubles. We'll see how it goes with the new one.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
