Apr 24, 2008, 11:28 AM
Personal Sales Rating: ( 8)
Drives: your mom crazy with my striking good looks
the microtech is a standalone from my reading. it will control directly the injectors and coil packs, which means the ECU doesn't have a say in what happens. I could be wrong though, I only researched this a little for a member on here at one point  never been interested in standalone myself, I've always wanted to be able to have the car inspected...
__________________
wtb 4g69 bottem end. pm me.
Offline
Apr 24, 2008, 11:45 AM
Personal Sales Rating: ( 3)
Drives: '05 Turbo RA
^no inspections here in MN!
Some "lesser" microtechs are just fuel piggys, some are standalone.
OT: I'm interested in this b/c in the kit I'm having built, I'm initially trying to see what's possible with the FIC, but standalone + me unplugging the CEL bulb may be the way I have to go...
Offline
Apr 24, 2008, 12:47 PM
Personal Sales Rating: ( 0)
Drives: 2005 Lancer Ralliart
Nice man!
__________________
2005 Ralliart
RRM Cold Air Intake
Offline
Apr 24, 2008, 02:29 PM
Drives: 06 Rio Red RA
Quote:
Hes using an lt-10 but as he posted before its still to be looked at since it seems that particular one wont work because of the car it was going to be installed beforehand. You are correct about the stock ECU not having a say though.
Offline
Apr 24, 2008, 02:53 PM
yeah, I thought it had to be the lt-10(or isn't there an 8?), I am not sure but I remember that I didn't think the piggybacks would work
you mean the lt-10 won't work? also, I thought those units drove different injectors...
__________________
Offline
Apr 24, 2008, 03:04 PM
Drives: 2004 Lancer RalliaArt
ya i would assume he would use the 10 like i am thats the only one i know that will work
Offline
Apr 24, 2008, 03:11 PM
its supposed to work and its been installed before but that one has slim to none chance to work....it was going in to a honda
Quote:
Originally Posted by qlitv
Micro tech (but don’t know if it’ll work cuz it was going to be installed on a Honda)
Offline
Apr 24, 2008, 03:13 PM
Drives: 350z
INsane!!!
Offline
Apr 24, 2008, 04:15 PM
Personal Sales Rating: ( 1)
Drives: Ralli
Well I'm sorry to say that I've been researching and been told that none of them are going to work crap!!!!
I don't get why the n/a piggy won't work I haven't try it but isn't the same?? if I play a little with the cells value with the wideband like if i was tunning it N/A but this time the fuel mix to 11.8 to 12.8 on WOT would be the same right?? I don't see why it wouldn't work
Offline
Apr 24, 2008, 08:02 PM
Drives: Lancer Ralliart
Looks good so far, keeps with an update
Offline
Apr 24, 2008, 08:53 PM
Personal Sales Rating: ( 6)
Drives: Evo X
the n/a piggy wont work because you cant tune timing w/ it...
the turbo piggy does that on map B
so, if you have a n/a piggy you can tune fuel... but you cant retard timing...
as for the microtech....
is an lt10
you can install it fully stang alone OR as a piggy
you can do this by hacking the wires pertaining to ignition and fuel only and leaving the rest to the oem
__________________
I look at it this way For centuries now man has done everything he can to destroy defile and interfere with nature poisoning the atmosphere over-fishing polluting the rivers and lakes, destroying wetlands and aquifers so when nature strikes back, and smacks him on the head and kicks him in the nuts, I enjoy that. I have absolutely no sympathy for human beings whatsoever. None. And no matter what kind of problem humans are facing, whether it's natural or man-made, I always hope it gets worse.
Online
Apr 24, 2008, 08:55 PM
is that an Evo?
Offline
Apr 24, 2008, 08:56 PM
ooops I see its not. My bad.
Offline
Apr 24, 2008, 09:59 PM
Drives: Ralli
What a mess.... hey Juan are you free on Saturday?  cuz I'm calling you as soon as I have everything done to mess with the piggy or micro or what ever it has to be done to tune.... do you still have that turbo piggy cuz I thought mine would work I forgot to tell you the part that my piggy is N/A
Offline
Apr 24, 2008, 10:23 PM
is an lt10
Well the problem here is that the lt-10 was configured for a Honda. Called the local microtech dealer and the guy pretty much just said it will be useless on the RA. I asked if they could reconfigure but he just said it would be a hassle and does not know if hes able to do it. Not surprisingly he offered a new one that would work but warned that the TPS sensor must be taken out and need a crank sensor from a Talon for the lt-10 to work on the RA.
As far as the timing goes wont the stock ECU conflict with the T-piggy map B?. As in the stock trying to revert to default? i kinda recall reading something about timing conflict
Si sabes algo de como bregar la lt-10 bajo la configuracion que tiene pues ayudarias a evitar tener un pisapapel de $650 porque se jodio el engine management por el momento
Offline
Tags
20wrx, 4g69, aem, crazy, evo, fic, fic8, forsale, fuel, injectors, install, lancer, mitsubishi, mivec, obx, project, rail, ralliaart, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
