Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Aftermarket Forced Induction Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 10, 2008, 10:19 AM   #1
Personal Sales Rating: (0)
Drives: 2006 Eclipse GS-T
Injector leaking
The last injector on the fuel rail is leaking fuel under full boost only. Not a lot but it should be fixed. I'm guessing Ralliart also has a returnless system. It's not an emergency cause they're working fine on regular driving. Any ideas what to do?
__________________
Garrett T3/T4 50 trim, Tial wastegate, Greddy BOV, NGK wideband, Lucas 550cc injectors, Aem Fic, custom manifold with ceramic coating + much more
Offline
Old Mar 10, 2008, 10:24 AM   #2
Personal Sales Rating: (8)
Drives: your mom crazy with my striking good looks
do you have an aftermarket pump? I don't remember more pressure=more leaking.
either replace the o-rings or if you had to customize the fuel rail to get it bolted down with the aftermarket injectors you could have either too much pressure or not enough pressure on the o-rings to seal properly. too much pressure and they will bind, too little and... well that's obvious.
__________________
wtb 4g69 bottem end. pm me.
Offline
Old Mar 10, 2008, 10:33 AM   #3
Personal Sales Rating: (22)
2003 Mitsubishi Lancer Evolution
colonelfox's Avatar
Drives: Rally Red Evolution VIII
Replace the o-rings and make sure they're properly seating in the rail. If it's leaking form the rail, the o-ring is bad, and the excessive fuel pressure at full boost is overcoming the seal of the o-ring.
__________________
Worlds fastest wingless rally red 8 owned by a guy named Josh in P.A. with an HX35, bronze Enkeis, cracked plastic backing on the drivers seat and painted red interior trim pieces.
453HP 377TQ .dll
Offline
Old Mar 10, 2008, 10:46 AM   #4
Personal Sales Rating: (31)
mdsevo06's Avatar
Drives: 06 WW IX GSR
Make sure you put some oil or silicone grease on the o-ring, before installing. Your lucky it's the last one, should be easier to replace. Good luck!
__________________
"If the regular lancer is powered by a hamster on a wheel, the Evo runs a meth'ed-out badger under the hood"
Offline
Old Mar 10, 2008, 11:45 AM   #5
Personal Sales Rating: (1)
Drives: .
IIRC.....aftermarket pump and stock fuel rail?
+1 on o-rings.
__________________
Offline
Old Mar 10, 2008, 11:56 AM   #6
The fuel pump is stock. It shows that it's more than capable of supplying enough fuel. I have an Evo 9 pump I was gonna put in, but it might not be necessary. Is the Ralliart returnless also? Does it have to be converted to return, or are the o rings enough?
__________________
Offline
Old Mar 10, 2008, 12:08 PM   #7
Personal Sales Rating: (7)
Drives: 06 TB Evo IX SE
Quote:
RA is returnless yes.
Offline
Old Mar 10, 2008, 09:06 PM   #8
Drives: Ralliart Thunder grey TURBO
Definately sounds more like an o-ring or injector seating problems. Make sure you tight them firmly and BTW what size injectors you got? For returnless system I recomend running at least 500cc's.
__________________
Got Boost.? Member 300+whp Club & Stock Internals..!
Offline
Old Mar 11, 2008, 05:41 AM   #9
I'm using the stock fuel pump and my injectors are 550 cc DSM ones.
__________________
Offline
Old Mar 11, 2008, 05:46 AM   #10
stock pump, rail, and aftermarket injectors? did you have to customize the rail at all to get them to fit? using wrx injectors you would have to make the rail mount further away, for instance. if you needed to finagle something that is most assuredly where your problem is starting. after checking the condition of the o-rings I would start checking my fitment.
__________________
Offline
Old Mar 11, 2008, 07:33 AM   #11
I'm gonna have to talk to the guy that did my turbo. He'll know what he did and how to fix it.
__________________
Offline
Old Mar 11, 2008, 10:12 AM   #12
colonelfox's Avatar
I'm sure it's a combination of things that lead to an already failing seal to break.
I think your best bet is to just put new o-rings on. It's really not that difficult and it'll prevent an engine bay fire. Any gas leak within the engine bay is serious for obvious reasons. There are several flash points under the hood of a car that could ignite gas vapors and leaks.
__________________
453HP 377TQ .dll
Offline
Old Mar 11, 2008, 11:22 AM   #13
Thanx for the info guys.
__________________
Offline
Old Mar 11, 2008, 06:10 PM   #14
colonelfox's Avatar
Good luck.
__________________
453HP 377TQ .dll
Offline
Old Mar 15, 2008, 06:40 PM   #15
Ok guys, it's fixed. We had to put a different washer on and tighten it up a bit. No leak under boost. And the engine doesn't shake anymore when idling either. I guess there was a bit of air leak around the injector.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
