Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Aftermarket Forced Induction Tech
04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 28, 2008, 08:46 PM   #1
Personal Sales Rating: (0)
Drives: Turbo RA
Check engine light codes
Hi all, im new to this site, and i was wondering if you guys could help me. I just turboed my Ralliart last friday, and all is good but the engine light came on, i have the rrm cel eliminator on the downpipe, so i got my car scanned and the codes that came up was P0171, and P0304. Thanks
Offline
Old Jan 30, 2008, 01:37 PM   #2
Drives: 2005 Lancer Ralliart
P0171 System too lean...DONT FOOL AROUND with that get it to a someone that knows what he is doing.....
As far as the P0304 no idea its not listed. My buddy at the dealership cant find it....recheck and get back to me.
Offline
Old Jan 30, 2008, 01:51 PM   #3
Personal Sales Rating: (4)
ModernRacer's Avatar
Drives: 2004 Ralliart Turbo
Send a message via MSN to ModernRacer
the second code is for Cylinder #4 missfire, so YES you are running way too lean in higher boost, wich means your car is not tuned properly, get it looked at A.S.A.P
Offline
Old Jan 30, 2008, 07:18 PM   #4
Drives: Turbo RA
Hi what could cause these codes to pop up, cause when i got the kit installed, i had it tuned by the installer at AFI performance, and he is good at what he does, cause he has tuned 3 or 4 RA in the city here, and they all don't have these problems. Also i have a wideband in my car and at idle it reads around 14.7 and when i go into boost it reads around 11 to 12.
Offline
Old Jan 31, 2008, 05:45 AM   #5
I have no idea why you are getting a code, something needs to be looked at. I have spoken to AFI (was looking into getting a kit) and ya he knows what he is doing. I don't know enough about your set up, I have been asking and from what I hear you have a 5th injector. I know there is a company here that is doing a turbo kit and i am in contact with them once and a while and from what I have heard the 5th injector is very unpredictable and not a good way to do it, it will work but not as good as changing the injectors....but that leads to tuning problems with our cars the O2 sensor keeps fighting us in open loop other than that I dont know too much about it.....I have heard that they are close to releasing the kit so I can only assume they got the issues worked out.....
Dont fool around with the lean issue...contact the company you bought it from ask for help....only thing I can suggest
Offline
Old Jan 31, 2008, 02:30 PM   #6
Drives: Turbo RA
well i went to the dealership the other day and they reset the code and now it has not come back on, the kit i have is with RRM. But i guess i will go to AFi again and get them to look at it again.
Offline
Old Feb 11, 2008, 04:06 PM   #7
Personal Sales Rating: (16)
chowetime's Avatar
Drives: Lancer 4g69
sorry to rebirth this thread... what spark plugs have you got in the car and what have you got in the way of injectors size or are you running a 1000cc 5th
I recently had a misfire in mine but mine was due to a faulty spark plug - thankfully I was driving at low speeds and low throttle so no damage was caused
__________________
SRI, K&N pod filter, headers, 21/2" exhaust, , D2 coilovers, 17" Speedy rims, Quaiffe LSD, lightened flywheel and Excedy clutch, twin piston front brakes, EBC Green stuff pads, GT throttle body, Accolade body kit modified, new JDM Double din, Alpine throughout, retrimmed interior black and blue saude,
track clip http://www.youtube.com/watch?v=kfCJ5PjRToI
drag race http://www.youtube.com/watch?v=DGcYaSg2-K0
headers http://www.youtube.com/watch?v=u7C3_ui5-24
Offline
Old Feb 13, 2008, 11:01 AM   #8
Drives: Turbo RA
I think the spark plug was for the 350z and i have no idea about the injector never asked but the kit is from RRM if that helps.
Offline
Old Mar 12, 2008, 07:46 PM   #9
Personal Sales Rating: (26)
Boeturbolancer's Avatar
Drives: Vulcan Mean Streak, Jeep Wrangler Unlimited X, YZ426F, F-250 Banks Diesel!
In boost you want to stay away from 12:1 ratio's on pump gas. 11's are great and 11.5 is a sweet target. You may have just a few lean spots in your tune. Try telling your tuner to richen it up a bit in those areas you see the 12's. That should correct the issue.
__________________
SC vs. TC...well, you wouldn't put a donkey in the Kentucky Derby would you? Are you ready to Turbocharge!! Always in moderation... boost responsibly.
Offline
Old Mar 12, 2008, 07:49 PM   #10
Another note... its usually the transition from off boost to mid level boosting that gets things on the lean side. An example would be 1/2 throttle from 2500rpms to 3500 rpm area where you'll see boost build and hover. WOT is easy to tune and usually at those points you'll never see 12's.
__________________
Offline
Old Mar 13, 2008, 10:28 PM   #11
Personal Sales Rating: (1)
SSP-Ralliart's Avatar
Drives: 04 Ralliart N/A, 68 Camaro
what is the gap on your plugs? If it is too close/far away then the intensity of your spark goes down and will cause a misfire. Or you may have a bad coil plug. I would try and get an ignition scope on that thing and do a power balance. See if there is any spikes. Also you can see what your average coil/spark voltage is and also your maximum. You might have a coil that isn't discharging enough voltage. If you can have someone do some diagnosis on the ignition secondary then you can find the problem right away.
__________________
Fastest Ralliart NA (Under Construction) SSP crankshaft, SSP camshaft, SSP cylinder head, SSP 14:1 pistons, SSP Flywheel, SSP twin disc clutch, soon more custom products for the drag car.
Fastest NA RA E.T. 12.7 @ 110 (Ran w/RRM products)
First RA in the 12's
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
