Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Aftermarket Forced Induction Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 15, 2008, 09:05 PM   #1
Personal Sales Rating: (0)
Drives: LANCER RALLIART 05
Blown turbo gasket?
as i was driving home from work yesterday not boosting, slow driving, i noticed lots of smoke coming out of the dumpipe and the exaust and when i got home noticed i was low on oil and it sounded like boiling water with the motor shut off. where do i get a new seal, or kit and how hard is it to install? that is if thats the problem.
im worried now and had an appt for a tune in 2 weeks,,damn,,,i got bad luck
i have the rrm 16g kit.\
and resources would be appreciated.
__________________
18" helo 834 deep dish black rims on nexen3000
Evo 8 carbon fiber spoiler
Beamer m3 carbon fiber mirrors
custom mess grills
short shifter
custom guages
r1 exaust
aem cold air intake,
2 10" solobarics in tha trunk runnin off a 2000w cerwin vega amp
and other minors
oh ya and now stage 1 rrm turbo,,,
Offline
Old Jan 15, 2008, 09:15 PM   #2
mirage 4g93t's Avatar
Drives: 2004 evo
the problems of boost..i know how that feels
Offline
Old Jan 15, 2008, 09:18 PM   #3
SPOOLED IX MR's Avatar
if theres smoke coming out of your exhaust doesnt that mean blown turbo?
Offline
Old Jan 15, 2008, 09:30 PM   #4
Personal Sales Rating: (11)
lancer2show's Avatar
Drives: 2005 Lancer ES/ 92 Talon TSI AWD
Quote:
it can be the seals are messed up, pinch in your oil return line etc.
__________________
LAST PIX OF MY 05 turbo lancer:
http://forums.evolutionm.net/lancer-show-shine/341242-my-last-pix-my-05-turbo-lancer.html
16G TURBO POWERED BY ROAD///RACE
Offline
Old Jan 16, 2008, 05:00 AM   #5
Personal Sales Rating: (8)
Drives: your mom crazy with my striking good looks
your oil return line is probably backing up into the turbo. the wastegate blowing back into the engine bay is another problem with the RRM kit. both of these are easy fixes, both have shown up on here. I would check your oil return before you cause any more problems, hopefully it's just started so your seals are still good
__________________
wtb 4g69 bottem end. pm me.
Offline
Old Jan 16, 2008, 05:01 AM   #6
resources: k3lv, geardownson, ROCK
the first two guys installed RRM's kit and worked out the bugs themselves. ROCK is RRM on evom.
__________________
Offline
Old Jan 22, 2008, 05:04 PM   #7
fixed
i found the problem, pinched oil return line,,revamped it and all is well there. now i have another problem, i got a check engine light after returning it to normal, code 0171 and it means running to lean. im not sure how this is. and my afr at idle is around 18-19 instead of 14.7, im worried now. i wonder if the sensor is jsut fowled because of the oil blowing by the sensor, or is there amybe something wrong? i hope i fix it soon though as im going for a tune next week and a dyno, i will be posting after.
__________________
custom mess grills
short shifter
custom guages
r1 exaust
and other minors
Offline
Old Jan 23, 2008, 09:34 AM   #8
yeah, try cleaning the MAF sensor with some electronics cleaner. it sounds like it's not reading the correct amount of air.
__________________
Offline
Old Jan 23, 2008, 12:08 PM   #9
Personal Sales Rating: (1)
Drives: Turbo'd RA 2006 MT
Check the airfilter on the charge pipe. The one that comes with the RRM kit has a metal cap in the middle. Mine had fallen off and I ended up with a CEL. Can't recall the code off-hand but it had to do with unmetered air. Once I saw the problem I just replaced the airfilter with a new one I bought from a local performance store and the CEL went away after about 30 kms.
Offline
Old Jan 23, 2008, 12:32 PM   #10
RarStlzLncr's Avatar
Drives: 2003 Mitsubishi Lancer OZ
sux
__________________
RRM Stage 2 Intercooled @ 8.5 psi, RRM 65mm Throttle Body, RRM Intake Manifold, RRM Fuel Rail, RRM Header, Buschur 2.5" Downpipe, RRM Cat-Delete, Greddy Evo 2 Cat-Back, RRM Stg. 2 Clutch, RRM Lightweight Flywheel, RRM Crank Pulley, NGK Plugs & Wires, RRM Strut Bar, Axxiss Brake Pads, RRM Slotted Rotors... Car Domain For More Info.
Offline
Old Jan 31, 2008, 08:04 PM   #11
WEll i fixed the problem but it happened again even though i fixed the oil return line, this time i lost 4 litres in a matter of an hour, im lost, no idea what to do, is the turbo maybe gone . or is this all jsut from the cold weather? its -40celcius here and has been for a while. i also have a vaccum leak, on the dyno the guy said i am reading 7 pounds of vaccum at idle and i guss it should be at around 20lbs, i already ripped everything apart twice and still cant find the problem, i sprayed break cleaner over everything and still couldnt fin a vaccum leak. any tips hints or help please. Im ready to part it out and buy a honda.
__________________
custom mess grills
short shifter
custom guages
r1 exaust
and other minors
Offline
Old Feb 1, 2008, 09:22 AM   #12
If you want to find a boost leak there are threads on here that will tell you how or give you links to "how to's" to make you own boost leak gauge. One website even sell a boost leak gauge. Search and you'll find it and if not I will see if I can dig it up this weekend.
You said you went to the Dyno, what were you results?
Offline
Old Feb 1, 2008, 10:51 AM   #13
Drives: 2006 Eclipse GS-T
You lost 4 litres of oil? That's serious **** buddy. You would be able to see where from it's leaking.
__________________
Garrett T3/T4 50 trim, Tial wastegate, Greddy BOV, NGK wideband, Lucas 550cc injectors, Aem Fic, custom manifold with ceramic coating + much more
Offline
Old Feb 2, 2008, 08:14 PM   #14
yea the oil is coming from the exaust side of the turbo into the exaust. Im going to do a boost leak test,,im leaking somewhere for sure cause on the dyno the guy said i was only showing 7 psi of vaccum at idle, so either the sensor is fouled or theres a big leak somewhere, im more worried about the oil though, its weird cause after i fixed it the first time there was no problems for aweek and now problems again, and worse, the oil was also coming out near the ring that joins the exaust n intake side of the turbo.. Im sick of it, im gonna rip it apart wednesday and try one last time , if it dont work, then im parting out . I hope the last kick at the can will work, any other tips are very welcomed, anything at all, im beyond desperate now
__________________
custom mess grills
short shifter
custom guages
r1 exaust
and other minors
Offline
Old Feb 9, 2008, 06:00 PM   #15
Personal Sales Rating: (2)
AdamRA's Avatar
Drives: Ralliart
Check the intercooler the oil is going somewhere.... My guess would be that the seals are gone.
__________________
RRM Turbo Kit,Stage 3 CM clutch,Autovation Pedals, Kartboy SS, Kartboy Bushings, Accolade grills, RRM cat-back, RRM lower tie bar, RRM Swaybar+Perches, RRM Clutchline, Gramlight 16" 57S W/ BFG KDW, ES Tails, Perrin Antenna, Defi BF Gauges (OP,WT,OT)
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
