Quote:
Originally Posted by silversleeper
Then don't modify your car, money wise like i stated a few years ago, not worth the money to do this. do some research and tell me if putting this back there worth all the work, and you still got to put piping back up to the intake and there is NO ROOM for it under the car. If you do run it along the route of the tunnel then i guess you will be blowing hot air into your intake since there is something else that gets really hot there also. Sorry, if your worried about smog don't mod your car, because they can fail you for almost any mod then since everything is before the cat.
I've been thinking about this...what about some fiberglass insulation between the exhaust pipe and intake pipe along the path...would that ward off enough heat?
