Mar 22, 2006, 07:32 PM
Personal Sales Rating: ( 1)
Drives: '04 Ralliart
Fuel CUT
Sorry I forgot to add to my other post. Will my car hit a fuel cut at a certain psi of boost on the stock ecu
Offline
Mar 22, 2006, 08:04 PM
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
Well, unless you get it moved up then I would assume so...
Offline
Mar 22, 2006, 08:41 PM
Personal Sales Rating: ( 6)
Drives: Evo X
the cut will not be determined by the boost but by the rpm either way too much boost wo/ fuel will lean the car and f-it up...
so if you want to control fuel do the logical thing..
buy a evo 8 fuel rail (yes it fits, stock or aftermarket), a regulator
and run the line so you can control fuel pressure
that was for free
__________________
I look at it this way For centuries now man has done everything he can to destroy defile and interfere with nature poisoning the atmosphere over-fishing polluting the rivers and lakes, destroying wetlands and aquifers so when nature strikes back, and smacks him on the head and kicks him in the nuts, I enjoy that. I have absolutely no sympathy for human beings whatsoever. None. And no matter what kind of problem humans are facing, whether it's natural or man-made, I always hope it gets worse.
Offline
Mar 22, 2006, 09:05 PM
Personal Sales Rating: ( 9)
Drives: 06 TB Evo IX SE
PR_Mivec > *
some nerdy schtuff for ya there.
Offline
Mar 22, 2006, 09:09 PM
Drives: Evo X
__________________
Offline
Mar 23, 2006, 07:14 AM
so an evo 8 fuel rail will fit on a RA???? is it a returnless system too?
Offline
Mar 23, 2006, 11:59 AM
Drives: 04 Ralliart 90 Eclipse GSX
If you plug the return line hole it is. It's much easier to convert from return to non return than it is the other way around. So make like a scene from Carrie and plug it up!
__________________
////AMG
The tires are EVIL and MUST be punished!
Offline
Mar 23, 2006, 12:29 PM
Drives: Evo X
Quote:
no.. the system on the evo is with retun ergo you can control pressure w/ regulator...
__________________
Offline
Mar 23, 2006, 06:37 PM
What did you do? Do you now have a return system on your car? And if yes how did you get the fuel line to return back into the tank?
Offline
Mar 23, 2006, 07:22 PM
I could totally be talkin outta my a$$ here but it sounds to me like he put an evo 8 fuel rail on with an fpr and a new fuel pump. With the new fpr and pump he now has a return system...? I'm a bit new to trying to figure all this stuff out so I apologize if I'm way off base.
Offline
Mar 23, 2006, 08:24 PM
Drives: Evo X
sighs*
instruments needed...
evo fuel rail, stock or aftermarket...
regulator (for evo)
a retun line from the rail to the tank how is this done.. god invented fittings, the drill and bits... drill the tank put a fitting to the tank, make sure you make a good seal.. put the line in the fitting and you are done..
__________________
Offline
Mar 24, 2006, 12:12 AM
Sorry, I guess I should have elaborated more. I assumed that you were running back from the rail to the tank, I just thought you had the aftermarket pump in there also.
Offline
Mar 24, 2006, 06:45 AM
Personal Sales Rating: ( 0)
Drives: 2004 Lancer Ralliart Sedan
YAY!!!!! lol and it was soooooo simple. i was trying to over analize things to solve my fuel problems, damn. your my hero. fuel hike fuel hike la la la la la la!! hooorah!
Quote:
Originally Posted by PR_Mivec
sighs*
regulator (for evo)
__________________
The surgeon general:
Didn't say crap about smoking HONDAS.
Offline
Mar 24, 2006, 10:43 AM
Drives: Evo X
Quote:
well i do have it all, so im guilty on all charges
btw i wasnt bashing so sorry if i sounded that way...
__________________
Offline
Mar 26, 2006, 05:52 AM
Man that sounds like it could be pretty dangerous messin with the gas tank with drill bits (metal on metal =sparks with gas?) even if I emptied the gas tank out, what could be some problems I could have? I mean if something was wrong. How did you do yours?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
