Feb 4, 2009, 01:29 PM
Personal Sales Rating: ( 5)
Drives: 05 Pearl White Ralliart AT
HID Temp Questions
So I'm going to be getting some HIDs for my RA and I was wondering what you guys think about this setup that I'm planning for.
8000K for the lowbeams on projectors and 6000K for the fogs
Do you guys think thats a little too much? Should go down a step for each? Should my fogs be brighter than the lowbeams? I don't know what would look good and want some opinions.
Offline
Feb 4, 2009, 01:35 PM
Personal Sales Rating: ( 0)
Drives: 06' Lancer Ralliart w/ S&S
hmmm i say keep the lows 8000 but go lower on the fogs temp
__________________
06 LB Lancer Ralliart w/ S & S Package
RRM SRI, RRM UDP
Halo Projectors w/ 6k HIDs
Tint, Wind Deflectors
RRM Depo Taillights
VG, S2k Antenna
PIAA H3 Yellow Bulbs
Alpine x200 Headunit
Falken ZE-912 in Stock Rims
Offline
Feb 4, 2009, 02:07 PM
Personal Sales Rating: ( 11)
Drives: Traded: WW 2008 Lancer GTS || Upgraded: WW 2009 Lancer Ralliart
8000k for projectors is too much.
4300k or 5000k is fine for low beams. 6000k is doable too.
Offline
Feb 4, 2009, 03:32 PM
Well then if i go with 6000K for the lowbeams what would you suggest for the fogs? Would 6000K all around be okay?
Offline
Feb 4, 2009, 04:08 PM
Personal Sales Rating: ( 2)
Drives: across median distracted by fellow Ralliart
I prefer 6000k because of the pure white. Keep in mind, you will be blinding everyone on the road unless you have HID certified projectors.
http://www.hidplanet.com/forums/view...37419d80c35740
http://www.youtube.com/watch?v=yVuSSdZNsZw
__________________
MagnaFlow - Injen - Zaklee - B&M - SpeedSource - Ralliart - Razo - Yokohama - Infinity - Pioneer - Sony - MTX
WTB: '04-'06 -ES,LS,OZ,RA- Headlights
Offline
Feb 4, 2009, 04:40 PM
Well these are the projectors I'm going to be putting the HIDs into... I hope that these won't cause too much of a problem even though they're not HID certified...
http://smg.photobucket.com/albums/v3...rrent=6393.jpg
__________________
Power: [x] RRM SRI [x] RRM UDP [x] RRM RA Timing Controlbox [x] RRM P/P Intake Manifold [x] RRM P/P Head [x] RRM Header/DP/HF Cat [x] Magnaflow Catback
Aesthetics: [x] Vortex Generator / Shorty Antenna [x] Angel Eye Projectors [x] 6000K Headlight HIDs [x] RRM Black Tails
Handling: [x] Megan Street Coilovers
Future Mods:
[ ] RRM Anti-Sway Bar
[ ] RRM Lower Tiebar
[ ] RRM Piggyback
[ ] RRM Stage 2 Cam
[ ] R1 Premium Rotors
Offline
Feb 4, 2009, 05:38 PM
2009 Mitsubishi Lancer
Drives: 2002 Lancer ES (Totaled); 2009 Lancer GTS
4300 would be ideal or 5000. your jus gonna take away u light output by going to 8000
Offline
Feb 4, 2009, 10:48 PM
Would 6K be okay for lows and 4300 for fogs then?
__________________
Future Mods:
[ ] RRM Piggyback
[ ] RRM Stage 2 Cam
Offline
Feb 4, 2009, 10:50 PM
Personal Sales Rating: ( 10)
Drives: 2006 EVO IX MR, 06 gsxr 600
yeah, the highest i'd go is 6000k on hids, nothing pass that. most stock car Hid is around 4300-5000k. More K, less light output, more color.
__________________
PSN ID: kdash106
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
Offline
Feb 4, 2009, 10:54 PM
^Agreed.
The fog color is really up to you. I'd say color/temp match them tho
Offline
Feb 4, 2009, 10:56 PM
Personal Sales Rating: ( 1)
Drives: 03 Mitsubishi Lancer Oz Rally, 04 Mitsubishi Lancer ES
Just remember, 6k puts out the most light or lumens or whatever you call it. 8k just start giving you that blue color, and above that is all the other colors like purple, green, pink, but you lose lumens. 6k is like a really bright white. 5k is white thats not as bright. I would go 6k on low, 5000 or 4300k on fog, or, just go 6k all around. I personally can't make up my mind on if I should go HID on my fogs either. Does anyone know what kelvin the stock evo headlights come with? 5k I believe.
Offline
Feb 4, 2009, 10:58 PM
2002 Mitsubishi Lancer
Drives: Lancer
I like how 8k low beams look with 3k fogs
Offline
Feb 5, 2009, 09:55 AM
Quote:
Most stock setups with HIDs from the factory run 4300k bulbs bc the lumen output is the highest at this temp. Whether or not the projectors look blue or purple or rainbow has to do with the lens, the cutoff shield position, and the reflector bowl. This pertaining only to HID certified projectors of course.
If anyone wants to learn about HID, go to www.hidplanet.com/forums
If you want to just ask questions and have everyone else do the leg work for you, do so, by all means. But, there is information out there for you to learn this stuff.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
