Ok, so I am overdue (at 44k miles) for a tranny fluid change on my '04 sportback (A/T obviously), and this is definitely one time when I wish the tranny was manual. The service would be so much easier (they have a drain plug).
My service manual isn't available to me for a while, and I haven't looked at it for six months or so, so I forget the process. Is this something I should do myself , or should I just pay a lube shop to hook up the A/T fluid machine, then change the filter at home on my own? It's unclear what the correct filter is for the vehicle. On
rockauto's site, it doesn't show anything for an A/T filter kit, and
looking up the 4g69 on a newer eclipse or outlander, it shows either a Beck/Arnley 0440322 (in pan) filter, or a B/A 0448000 (spin-on) filter. Are either of these correct?
So what should I do? A local lube shop offered to do the fluid change for $60 if I bring the fluid, and my mechanic said just a fluid change would be about $100. How much do I need to bring if they need to run it through the machine? The guy at the lube shop thought about 10-12 quarts. I'm thinking about the fluid that mitsubishi recommends, unless there is something better.
Is a transmission shop my best bet? WTF? This is way too complicated.
