Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart How-to's/Installations > 04-06 Lancer Ralliart How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 17, 2009, 10:40 AM   #1
Personal Sales Rating: (0)
Drives: 2006 Lancer Ralliart
Ralliart 06 help...
I bought a evo 8 steering wheel i wanted to know if it fits on 06 lancer ralliart because im having problems installing it please any help would be taken in consideration.
Offline
Old Sep 17, 2009, 11:16 AM   #2
Personal Sales Rating: (5)
Raikiri's Avatar
Drives: 05 Pearl White Ralliart AT
i believe it was with the 06 RAs that in order to install the evo wheel you needed the evo hub cause there were fitment issues. im not 100% certain on that so would anyone be able to verify that?
Online
Old Sep 17, 2009, 02:43 PM   #3
Personal Sales Rating: (4)
Drives: Lancer Ralliart 2006
I remember reading something like that as well ... a search on the forum should do the trick !
Offline
Old Sep 17, 2009, 02:50 PM   #4
rdc
Personal Sales Rating: (3)
rdc's Avatar
Drives: dodging potholes at an area near you
It's been talked about already. The Evo steering wheel only fits up to '05 model years because the '06 hub is smaller. You'll need to swap it out in order to make it fit (check the regular lancer forums, I think there's a how to on that).
__________________
Quote:
Originally Posted by BLKRalliArt04
Man, my gf said she wasnt gonna get me anything for my car, says buying stuff for cars is stupid.
Quote:
Originally Posted by Myszkewicz
I got myself the RRM Piggyback for Xmas. Buying stuff for girlfriends is stupid. :lol:
04 R/A
PR = MIVEC Nation!!
Offline
Old Sep 17, 2009, 06:15 PM   #5
Personal Sales Rating: (9)
2004 Mitsubishi Lancer
migueralliart's Avatar
Drives: 2004 N/A RALLIART , 2003 6MT G35 coupe
Quote:
And the 04' model too
__________________
RALLIART TURBO PARTS FOR SALE HERE
Offline
Old Sep 18, 2009, 04:10 PM   #6
Drives: 02 Lancer OZ, 06 Lancer Ralliart
Thanks to robyn
it does work couple of minor things u need to do.
DISCONNECT THE BATTERY AND DO NOT DISASEMBLE THE STEERING WHEEL FOR ABOUT 30 MINUTES
so the SRS system discharges it stored power and you don't blow the airbag in ur face
use this time to take off the lower dash trim panel by ur knees, and knock the evo shaft out of the column sleeve it may of maynot come with
1) swap the entire steering column shaft with that of an evo 8-9
2) take your 06 RA shaft out of the column sleeve(its the tube around ur shaft has bearing at either end
3) put the evo shaft into RA sleeve, be advised the evo shaft changed diamater slightly at the lower portion that would go into the lower bearing of the column sleeve, so u have to manual adjust how far u put the column into the shaft so that the bearing doesn't restrict the ease of turning the column and wheel
4) *caution* remove your air bag gas generator from your RA steering wheel and bore the mounting holes a touch bigger, u'll see exactly what i mean when u try to place the generator into the evo wheel
5) you can custom mount the cruise control lever from your RA into the evo wheel, take some imagination and patients
6) take the car into the dealer to have your SRS system reset and bobs ur uncle your entire SRS system SHOULD work as you will have no SRS faults
pretty sure that covers it... its a simple swap just a little on the tedious side, i was gunna make a DIY forgot my camera when doing the swap
__________________
RALLI////////ART NATION
White 2002 O.Z. Lancer (RIP)
White 2006 Lancer Ralliart
RRM Intake Manifold, RRM Cold Air Intake, EVO 8 Spoiler, EVO 8 Gauge Cluster, EVO 7 Steering Wheel, EVO 9 SE Seats front and rear, EVO 7 Door panels.
Soon to be on the car:
RPW Stage 3 Cams, RPW Cam Gears, Piggyback unit, RPW fully coated headers + downpipe, ACCOLADE Front Bumper, Rear Bumper, Fenders, Hood, & Side Skirts.
WTB: Cerious Performance Shaven Trunk for the 04-06 Lancer. PM with any offer.
Offline
Old Sep 25, 2009, 09:34 AM   #7
Quote:
Originally Posted by kaoscage View Post
Thanks to robyn
Where can i find the evo shaft!!
Offline
Old Sep 25, 2009, 04:13 PM   #8
Contact russell @ mitsubishiparts.net
__________________
Offline
Tags
04, art, bumpers, cluster, column, evo, oz, ralli, ralliart, rear, steering, swap, wheel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
