Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart How-to's/Installations > 04-06 Lancer Ralliart How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 29, 2009, 12:46 AM   #1
Personal Sales Rating: (3)
BlackRaven's Avatar
Drives: '05 Turbo RA
04-06 RA Trans Fluid Change - Helper Pics
Hey everyone-
It was Christmas in May at my house, and I got around to changing my tranny fluid this afternoon. I'd looked for the threads outlining the directions, and the one posted at Evo Motorsports is great:
http://www.evomoto.com/tech_info.php?tech_id=26
However, I thought I'd throw up a few pics I took while doing it, maybe help a fellow RA owner out. Use these pictures in conjunction with the directions at the Evo Moto link.
I love this sight as I pull in my driveway...the top box was from Buschur Racing and had 3 qts of BG Synchroshift II.
The fill plug is located on the front side of the transmission and is labelled "Oil". Here, I have the bolt out and some hose I used to fill 'er up:
from above:
The drain plug is on the driver side of the transmission, more toward the back of the car. The pictures on the Evo Moto link above show a magnetic drain plug...from the factory, ours are not magnetic. The 24mm bolt has a rather shallow head. Here's two pics of the drain hole:
closer...
This truly is an easy thing to do. Just be careful; when that drain plug comes off, the old tranny fluid shoots outta there, so get your catch pan ready. After I was all done (including the obligatory I-just-worked-on-my-car cigarette), the BG Synchroshift II felt great...I should have done this 10,000 miles ago
Hope this helps!
Offline
Old May 29, 2009, 07:01 AM   #2
EvoM Super Moderator
Personal Sales Rating: (10)
2009 Toyota Tacoma
My Garage
otter's Avatar
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Send a message via AIM to otter
You're beyond due on flushing your brake fluid.
__________________
READ EVERYTHING IN THIS LINK BEFORE PM'ING ME ABOUT WHY YOU CAN'T POST IN THE CLASSIFIEDS!!!
Problem with a post or thread? Use the report post button, it's faster than PM'ing a single Mod.
Read and obey the rules to help keep this forum a great place!
My Ralliart
Michigan Evo/Lancer club
Offline
Old May 29, 2009, 08:09 AM   #3
BlackRaven's Avatar
It's an optical illusion, I swear...
BTW, Otter, could you change the main thread title? It of course should read "Trans Fluid"...note to self, don't start threads between the hours of 12am and 4am
Offline
Old Jul 21, 2009, 11:23 AM   #4
Personal Sales Rating: (1)
asplodzor's Avatar
Drives: '03 ES Lancer
Just to make sure we're all on the same page, this is for a manual transmission, not an automatic, right? Also, any difference between fluid amounts and types between the manual transmissions in different years and series? ('02-'09, and ES, RA, Evo for instance)
Offline
Old Jul 22, 2009, 08:57 PM   #5
insomniac_evo's Avatar
Drives: 04 Black Ralliart
a few questions here:
how do you know its at the correct level when its full? i heard its bad to overfill the trans fluid
is the car on jacks or on the ground? when filling it up i mean.
thanks
__________________
LANCERNATION.NET
rallyart...rallyyart...its RALLIART dammit!!!
Offline
Old Jul 23, 2009, 02:19 AM   #6
Personal Sales Rating: (0)
2004 Mitsubishi Lancer
joeyj's Avatar
Drives: 04 RA
thanks
you want to fill it till it is level with the bottom of the hole that you fill it in.
from service manual;
"Fill with gear oil API classification GL-4 SAE 75W - 85W or 75W - 90 until the level comes to the lower portion of filler plug hole. " (about 2.3 quarts)
doesnt matter if its on jacks, as long as it is level and not at an angle.
Quote:
i know the aforementioned amounts and specs are good for all 04-06 RA's, if it is the same for the es, then it will be the same for the 02-07 models, granted im not sure, but I would bet the evo's i gonna be different.
__________________
[x] RRM piggyback
[x] RRM UDP
[x] RRM SRI
[x] RRM SS clutch line
[x] RRM rear strut bar
[x] 2.5 Otto Exhaust
[ ] RRM stage 2 Camshaft
[ ] RRM stage 1 clutch
http://www.cardomain.com/ride/2941543
Offline
Old Jul 25, 2009, 08:21 PM   #7
Personal Sales Rating: (2)
AdamRA's Avatar
Drives: Ralliart
thanks
If you over fill it will not get up to the proper temperature and will cause grinding. I know from experience. Didn't pay attention to how much was going in.
__________________
RRM Turbo Kit,Stage 3 CM clutch,Autovation Pedals, Kartboy SS, Kartboy Bushings, Accolade grills, RRM cat-back, RRM lower tie bar, RRM Swaybar+Perches, RRM Clutchline, Gramlight 16" 57S W/ BFG KDW, ES Tails, Perrin Antenna, Defi BF Gauges (OP,WT,OT)
Offline
Old Jul 25, 2009, 08:31 PM   #8
2009 Toyota Tacoma
My Garage
otter's Avatar
You can't overfill the manual trans if the car is sitting level (stock ride height) when you fill it. Just keep pouring fluid in until it overflows back out the hole.
__________________
My Ralliart
Offline
Old Aug 19, 2009, 12:46 PM   #9
2006 Mitsubishi Lancer
JPxM0Dz's Avatar
Drives: Cool Silver '06 Lancer RA {S & S}
Send a message via ICQ to JPxM0Dz
Nice!
Offline
Old Sep 11, 2009, 12:27 PM   #10
deathsythe99's Avatar
Drives: 04 lancer ralliart
i know this is kinda dumb but does it matter what kind of oil we use? because im thinking of putting in the eneos 75w-90 gear oil pls reply
__________________
injen short ram
3" exhaust piping
eye lids, guage pillar
alpine sterio and all speakers
Offline
Old Sep 11, 2009, 02:23 PM   #11
2009 Toyota Tacoma
My Garage
otter's Avatar
Haven't heard of anyone using Eneos oil in our trans. That stuff is fairly new/uncommon in the US (I had never even seen it before until last month.) People generally go with OEM, BG, Redline, Amsoil, or GM Synchromesh. In theory, any GL-4 oil should be fine, but our trans tends to feel finicky. I've used OEM, BG, and Amsoil. I prefer BG of those 3.
__________________
My Ralliart
Offline
Tags
06, 2003, 2004, automatic, change, fluid, flush, kind, lancer, manual, put, ralliart, tranny, trans, transmission
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
