Sounds like you need either a radio relocation kit, which allows your radio to be installed where the cubby hole is below the HVAC controls, therefore giving you the ability to install gauges where the radio used to be. Or you can get a plate that installs where the cubby hole is allowing you to place gauges there, OR you can get a pillar pod which replaces the pillar from the dash to the roof along the windshield with gauges OR you can get a steering wheel top mounted pod OR you can also get a dash top gauge pod.
__________________
Quote:
Originally Posted by otter
I don't like the handicapped stalls. I feel like I'm too far away from the door to prevent someone from barging in (this has happened before), since the locks on stalls usually suck. Some 4-5 y.o. kid pushed his way through the lock, saw me, turned around and left, leaving the door hanging open. Couldn't immediately shut it due to my ass being in the middle of birthing something unholy.
As for the urinal rules, most guys put way too much thought into it.
