Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart How-to's/Installations > 04-06 Lancer Ralliart How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 1, 2009, 08:56 PM   #1
Personal Sales Rating: (0)
skurd3damike's Avatar
Drives: 2006 WHITE RALLIART
Need help on timing mark
After all the research im more than ready to do my valve lash adjustment with the tools and procedures. I got everything figured out except the MARK that I need with the pulley. I changed my pulley and did not put any marks on it so it screw me up a little bit. Im looking @ my stock pulley right now and there is a hole on the side, when the stock pulley is installed does the little hole needs to be aligned with the "T"mark on the side? Do I need to re-install my stock pulley or there is another way to do it easier? Thanks.
Offline
Old Apr 1, 2009, 09:45 PM   #2
EvoM Super Moderator
Personal Sales Rating: (10)
2009 Toyota Tacoma
My Garage
otter's Avatar
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Send a message via AIM to otter
On the stock pulley, it's the notch on the edge (not the hole) that needs to line up with the timing mark on the timing belt cover. However, with the UDP, this is really easy to do. If you put the keyhole on the pulley at 3 o'clock, then the engine will be at TDC.
__________________
READ EVERYTHING IN THIS LINK BEFORE PM'ING ME ABOUT WHY YOU CAN'T POST IN THE CLASSIFIEDS!!!
Problem with a post or thread? Use the report post button, it's faster than PM'ing a single Mod.
Read and obey the rules to help keep this forum a great place!
My Ralliart
Michigan Evo/Lancer club
Offline
Old Apr 1, 2009, 10:40 PM   #3
I never doubt that you will be the ONE answering my question! Thanks much Otter.... I will be doing mine first thing tomorrow......
Offline
Old Apr 2, 2009, 03:43 PM   #4
RALLIART15's Avatar
Drives: 05 LANCER RALLI///ART
Send a message via AIM to RALLIART15
Isn't Otter just awesome...
__________________
JAKAZZ
.._\/_..4 Life.._\/_..
/_/ \_\_____/_/\_\
05 RA Tarmac Black ED "WALKER" kit. RRM P/P Head, P/P IM, Stg II cam, UDP, CAT Bypass &O2 Elim. EVO VIII Gauge Cluster.
**COMING SOON**
Boosted RA with goal of 300+WHP done by 2010
Offline
Old Apr 3, 2009, 01:43 AM   #5
Otter is the MAN! 3 o"clock was precisely right..... Mine was done this morning and engine sounds a lot better.....
Offline
Old Apr 4, 2009, 12:22 AM   #6
D1no's Avatar
Drives: 2004 Ralliart
Otter, Thanks for a great How to.
I checked the steps to do this adjustment last weekend. Turned the wheel to the right and looked through the opening at the pully. On the outer edge of the square hole where you insert the wrench I noticed a white painted dot. If you put this dot at 12:00, it will get the notch on the pully's edge real close to the timing mark. Centering this dot saves some time.
__________________
Alpine 9830 - eD 6500s-JL 300/2 - Arc Audio Flatline 12- Arc Audio 1000.2T
Offline
Tags
evo, lancer, marks, timing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
