Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart How-to's/Installations > 04-06 Lancer Ralliart How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 15, 2009, 05:16 PM   #1
Personal Sales Rating: (1)
2006 Mitsubishi Lancer
AznRico's Avatar
Drives: 06 Ralliart AT
Help! Splicing wires for headlights?
I recently just bought headlights from depoautolights.com, but after taking apart my car, I find that the headlights are made for European cars? Therefore the plugin for the main light is different....
Is there a way that I can make these headlights fit to the stock car? you can see the end of the plug of the new headlights here: http://depoautolights.com/mitsubishi...112892ef819b68
If not any fix to getting these headlights in?
Offline
Old Feb 15, 2009, 09:42 PM   #2
EvoM Moderator
Personal Sales Rating: (2)
Myszkewicz's Avatar
Drives: '04 Lancer Ralliart, '82 Honda Nighthawk, '82 Suzuki GS1100, '81 Suzuki GS1100, '74 Volkswagen Bus
Send a message via AIM to Myszkewicz Send a message via MSN to Myszkewicz
I'd recommend against messing with the stock harness, just in case you want to go back to stock or sell the car.
If you can fit some crimp-on spade connectors over the terminals on that plug, you could try making an adapter harness out of a couple old 9007 bulbs.
I just did something very similar to control my hi/lo HID kit.
EDIT: Something like this plug:
and this plug:
and three short pieces of wire connecting them.
Offline
Old Feb 16, 2009, 01:39 PM   #3
AznRico's Avatar
thanks for the reply! so i ended up starting to splice the parts... its a long weekend so this is temporary until i can find parts to make the harness...
the stupid thing is that ALL the plugs dont fit (including parking/signal lights) therefore I have to change the cord ends on my car and new headlights to make them fit...
Offline
Old Feb 16, 2009, 10:14 PM   #4
EvoM Moderator
Myszkewicz's Avatar
Again, I'd very much recommend against cutting your stock wiring., If you can manage to use the stock bulb bases as connectors, go with that. Otherwise, use spade connectors or plugs like I posted before to make adapters. The less you can hack your stock harness, the better off you'll be in the long run.
I plan on keeping my car until it's beyond repair. I still haven't hacked any of my wiring beyond a 10-second return to stock.
Offline
Old Feb 16, 2009, 10:51 PM   #5
AznRico's Avatar
yea okay, i just made a temporary connection for now... i will have to make a harness later
Offline
Tags
connector, headlight, headlights, light, signal, splice, splicing, wires
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
