Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart How-to's/Installations > 04-06 Lancer Ralliart How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 28, 2008, 08:56 PM   #1
Personal Sales Rating: (0)
sicnevol's Avatar
Drives: 2004 Lancer Ralliart
Send a message via AIM to sicnevol
Starter
Okay, I have my 2004 Ralliart, and the starter is going out. So i'm poor, but i need to fix it because i drive to and from school everyday like 30 miles. So getting stranded would suck. Can anyone give me step-by-step for an install of the new starter?
How hard is it? I've never done any mod's or anything. I'm also lazy, so if its super tough, I'll have to take it somewhere.
Also would like some recommendations for a shop in or around Akron Ohio, because the dealer ****ed me when i went to get my suspension fixed.
Thanks for the help.
__________________
Honda's are like Tampons, Every pussy has one.
Since the one thing we can say about fundamental matter is that it is vibrating, and since all vibrations are theoretically sound. Then it is not unreasonable to suggest that the universe is music and should be perceived as such
Offline
Old Nov 28, 2008, 09:50 PM   #2
EvoM Super Moderator
Personal Sales Rating: (10)
2009 Toyota Tacoma
My Garage
otter's Avatar
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Send a message via AIM to otter
It's a piece of cake. Two bolts and a wiring harness. The starter is located underneath the exhaust manifold, under a heat shield. Once you get down to it, you'll see that it's pretty self explanatory. Basically, remove the exhaust manifold heat shield, to give you a bit more room to work, then remove the heat shield protecting the starter, disconnect the wires to the starter, then remove the two bolts holding in the starter.
I'm pretty sure it can be done without removing the exhaust manifold, but if you don't have enough space to work, then you'll have to pull it.
__________________
READ EVERYTHING IN THIS LINK BEFORE PM'ING ME ABOUT WHY YOU CAN'T POST IN THE CLASSIFIEDS!!!
Problem with a post or thread? Use the report post button, it's faster than PM'ing a single Mod.
Read and obey the rules to help keep this forum a great place!
My Ralliart
Michigan Evo/Lancer club
Offline
Old Nov 28, 2008, 09:56 PM   #3
2004 Mitsubishi Lancer
joeyj's Avatar
Drives: 04 RA
take off heat shield and intake box (or aftermarket intake if you have that), and then you remove things in this order according to the service manual
1.STARTER COVER
2.HARNESS CLAMP
3.STARTER CONNECTOR
4.STARTER TERMINAL
5.STARTER ASSEMBLY
6.STARTER COVER BRACKET
The numbers DO correlate to the picture
see pic here
__________________
[x] RRM piggyback
[x] RRM UDP
[x] RRM SRI
[x] RRM SS clutch line
[x] RRM rear strut bar
[x] 2.5 Otto Exhaust
[ ] RRM stage 2 Camshaft
[ ] RRM stage 1 clutch
http://www.cardomain.com/ride/2941543
Offline
Old Nov 29, 2008, 06:17 PM   #4
sicnevol's Avatar
Thanks! I decided to re check the battery and spark plugs before i replaced the starter.
It was the battery.
Now I know for next time.
Its about to roll over to 100k so I'm sure I'll have to put one in sometime.
Thanks again.
__________________
Offline
Old Dec 19, 2008, 09:10 PM   #5
myfakeevo's Avatar
Drives: 2004 lancer ralliart
normally when its the starter it will make a grinding noise, not a lagging noise for future reference.
Offline
Old Dec 20, 2008, 08:28 AM   #6
2009 Toyota Tacoma
My Garage
otter's Avatar
Quote:
Dead starters will either do nothing, due to a dead solenoid, or make a click and do nothing, if the starter's drive shaft is rusted in the housing.
__________________
My Ralliart
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
