Feb 24, 2008, 01:52 PM
Personal Sales Rating: ( 0)
Drives: 2006 Mitsubishi Lancer Ralliart
Anyone Hook up a Oil Press Gauge?
I was wondering if anyone here has installed a Oil Press. Gauge in their RA yet?
if it may be installed in the same location as the EVOs, which is by the oil filter
Thanks
Offline
Feb 24, 2008, 01:53 PM
Personal Sales Rating: ( 21)
Drives: 03 Silver Evo 8 ; 95 Honda Civic dx coupe(beater)
do you have plugs in your oil filter holder for it to connect into?
__________________
- RNR DP
- RNR TP
- Magnaflow Exhaust
- K&N Cone Filter
- ACT HDSS
- EVO IX DV
- HKS 272/272 (-4/-1)
- Unorthodox Racing Tuner Cam Gears
- AEM WIDEBAND
- Walbro 255 lph fp
- ETS LICP
- JDM Map w/ECU Boost Control 23psi
- Tein S-Tech Springs
SELF TUNE
Best - 12.6 @ 107.38 mph
Boost is one hell of a drug!!!
Offline
Feb 24, 2008, 03:26 PM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
I have one, but I did it by replacing the stock sender with the aftermarket one.
Offline
Feb 24, 2008, 03:57 PM
Personal Sales Rating: ( 2)
Drives: 16G powered Ralliart
Look into getting the oil adapter plate, you can find em through Prosport I believe.
__________________
2006 Turbo Ralliart
2005 Yamaha R6
Offline
Feb 25, 2008, 06:11 AM
Personal Sales Rating: ( 8)
Drives: your mom crazy with my striking good looks
you don't need the adapter plate. mitsu has left us a spot right above the filter facing the wheel well. 1/8th npt and everything.
__________________
wtb 4g69 bottem end. pm me.
Offline
Feb 25, 2008, 06:12 AM
Quote:
it has the same output signals as the stock one? sounds like the best option I have heard so far...
__________________
Offline
Feb 25, 2008, 08:33 AM
Quote:
Yeah, it comes with two outputs, one for the gauge and one for a light, though I don't currently have the light hooked up, just the gauge. This particular sensor triggers the light at ~5 psi, but our cars idle at 3-4.
Offline
Feb 26, 2008, 04:03 PM
Drives: 2004 Lancer RalliaArt
i put the sending unit on the back of the block were odder did works great there!
Offline
Feb 27, 2008, 05:41 PM
Personal Sales Rating: ( 16)
Drives: Lancer 4g69
slightly ot but which would be of more benificial an oil temp or oil pressure gauge?
__________________
SRI, K&N pod filter, headers, 21/2" exhaust, , D2 coilovers, 17" Speedy rims, Quaiffe LSD lightened flywheel and Excedy clutch, Accolade body kit modified, new JDM Double din, Alpine throughout, retrimmed interior black and blue saude,
track clip http://www.youtube.com/watch?v=kfCJ5PjRToI
drag race http://www.youtube.com/watch?v=DGcYaSg2-K0
headers http://www.youtube.com/watch?v=u7C3_ui5-24
Offline
Feb 27, 2008, 06:02 PM
Personal Sales Rating: ( 12)
Drives: '04 'mac black EVO8, '04 black onyx IS300, 1998 eclipse gst(R.I.P.), 1993 Honda Accord A.E., 1990 Ford Mustang-built 302(sold), 1971 Chevy Elco built 307
pressure is more relevant. IF you have no oil pressure, what is the temp going to do for you?? it is BEST to get both in an evo, since it has a factory oil cooler. but if your limited to space, oil pressure is best.
__________________
Helix intercooler pipes,Helix 3" DP,Helix 3" exhaust,Invidia o2,Helix DNA coilovers, WORKS filter,3" WORKS HFC,Greddy Type S,FPWR Turbo w/Ti internals,10.5 Hotside,Works p2 flash w/boost control, Works 269 cams,Revolver valvesprings/retainers,ARP headstuds,Walbro 255,6000k HID upgrade,DoLuck CF lip,Omori multicolor electronic 60mm gauges,B&M short shifter,Pocketlogger,HKS type 1 TT,custom grounding kit,voltage stabilizer,Axas shift indicator light
Offline
Feb 27, 2008, 07:10 PM
to me you should have both; pressure so you can be sure your pump is operating like it's supposed to and temperature because that's how you can tell everything is cooling like it's supposed to  if you wanted to go overkill on a turbo car you could go both before and after the turbo with temperature sensors.
__________________
Offline
Feb 27, 2008, 08:07 PM
IMO, pressure is easily more important. You can get a good idea of your oil temp from the oil pressure. I wouldn't bother with a temp gauge unless you've gone turbo.
Offline
Feb 28, 2008, 06:54 AM
especially with an aluminum head temperature is important. oil and coolant both wick heat from the engine, but at different rates. these temperatures will give you a real picture of when the engine is warm enough to beat on instead of a partial picture. coolant heats up entirely too fast to start beating it when that needle levels off.
__________________
Offline
Feb 28, 2008, 08:38 AM
Yeah, but a pressure gauge will still give you that info. Since colder oil doesn't flow as well, it'll register a higher pressure. I don't recall if you have a pressure gauge or not, but if you do, I'm sure you've noticed that when you start the car cold, at idle the pressure is anywhere from 60-80 psi. It takes 15-20 minutes of driving before the oil finally gets hot enough to drop down to ~5 psi at idle, where it should be. This is also handy info for if you have to adjust valve lash, as it's a good way to be sure that you've got the engine hot enough.
Offline
Mar 4, 2008, 02:34 PM
+1 otter
Offline
Tags
1g, 98, acorrd, civic, dsm, gauge, guage, honda, hook, o2, oil, place, points, pressure, temp  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
